Old 12-16-2011, 11:48 AM
Originally Posted by cobrarkc View Post
Mike
Just curious, what system was Dynoformance using with this setup?
Dynaformance supplied a kit comprising various manufacturers stuff and their own wiring harness. The ECM was a generic unit by Redline/ Piranha and you supplied your own MSD distributor. You can still get that kit from Eight Stack and if you just want something that starts up and runs then I suppose they're OK. I have to say the kit was complete to the last nut, bolt and vac pipe and you get quite a nice instruction booklet but it does not have the capabilities that an IR system really needs.
Mike
Old 12-16-2011, 06:30 PM
Dwight's Avatar
Smile Eight Stack
here is a bad picture of my set up. Not running yet, but soon.
Dwight
Old 12-17-2011, 05:37 AM
TButtrick's Avatar
That is gorgeous but when "How much does it cost?" is not listed in the frequently asked questions, its usually too much for me.
This is also scares the crap out of me. I hear this over and over about many custom EFI systems.
Originally Posted by kobrabytes View Post
Took several years to tuning tho...
Old 12-17-2011, 06:15 AM
Dwight's Avatar
Smile tuning
I run an Ford EFI system on my Cobra and it took several years for me to get it tuned correctly. The big problem is I'm always on a budget.
Part of it was a learning curve for me and the mechanics I used thought they could help but did not understand the fuel injected hot rod that I had. Each was able to help solve a problem but not all of them. I had a Ford Mustang processor but a lot of aftermarket speed parts that made it hard for the processor to handle.
I found a local Ford mechanic who had a racing back ground that solved all the small problems. Things like 5/16 vacuum hose on a 1/4 barb. A new mass air meter that would not work with my system but worked fine on my buddies Mustang??? Go figure.
A dyno shop in Memphis burn me a custom chip to make everything work together. Not I was making hp and car was street-able.
Fuel injection is simple. You need a processor, coolant temp. sensor, air temp sensor, throttle position senor, oxygen sensor, and a few other common parts, intake, injectors, correct distributor, wiring harness. etc.
The processor receives the information from the sensors and then applies the correct amount of fuel and ignition.
The more horsepower you want to more sophisticated the system has to be. But for the street motor it does not take a lot.
I love it, motor always self tuning for max performance. When it stops working then you have to find the component that's broke. That where you need a shop (or mechanic) that has the tools to solve the problem.
I'm lucky that I have a friend with all the tools and knowledge.
The Eight Stack system will be a lot easier to work with because I can download a program into processor and make changes (that is, my buddy can).
I found a speed shop with a dyno about 80 miles from my house. Jon only works on Ford fuel injection cars and his rates are very reasonable.
$100 an hour for dyno tuning. He will do two pulls for $50 with no tuning.
I think I can get 500 hp out of a 347 with the Eight Stack system. Now I need to find a couple of thousand so I can buy a stroker kit.
Dwight
Old 12-17-2011, 06:26 AM
Dwight's Avatar
I forgot one thing that TButtrick bought up
in years pasted company sold system that where not street tested or complete. I think the new companies sell a system that it tested and proven to work.
Components are a higher quality and matched to work with the whole system. Computers (processors) are much better and cheaper.
I think the standard fuel injected system is $3000 to $6000. Which is twice the cost of a carb'ed setup.
I think the cost is justified when you raise the hood and look at what appears to be webbers. And it has all the performance and street ability of a new car.
I think I have died and gone to car heaven
see ya on the road
Dwight
Old 12-18-2011, 09:35 AM
Varmit's Avatar
Cobra Make, Engine: Superformance#2352/Aluminum SO/490 c.i. 650 h.p. 605 tq.
I REALLY want one of these systems, but I'm really concerned about how much tweaking needs to be done once it is installed. Hate dealing with issues, once installed just want to "kick the tires and light the fire and do"
Old 12-18-2011, 11:55 AM
Dwight's Avatar
Smile
give me a couple of weeks and I'll let you know how it goes. But now I think it's a no brain er, plug and play system. My problem was everything was installed incorrectly. I had to remove the intake and start over. I did have a hole drilled into the intake just above the t-stat so I could install the temp. sensor. I used the other factor hole to install the temp. sensor for the dash gauge.
I will take it the the dyno tuner because I want the max out of the system. I am gathering parts and info for a 347 motor and I will use this system on it. Shooting for 500 streetable hp. Like I have in my Cobra.
Dwight
