Old 01-13-2012, 06:51 AM
Rare Iron's Avatar
Default New Purolator Oil Filter for Synthetics:
Something to keep an eye on - I have used synthetic oil since the late 80's on my daily driver vehicles. This is a new filter by Purolator & it may be a good one: Filter designed for synthetic oils | Truck Parts & Service | Trucking Aftermarket | Heavy-Duty Truck Parts and Services
-Eric
COBRAPACK Mufflers
www.classicchambered.com
Old 01-13-2012, 09:35 AM
Best oil filter on market after reviewing filtration rates, construction and pressure drop is royal purple
Old 01-13-2012, 10:08 AM
Bxx1's Avatar
Seems like a good filter but not the best available as many top tier filters are rated 99.9% at 20 microns. Seems like marketing hype to me.
Old 01-13-2012, 03:09 PM
joyridin''s Avatar
Actually, I don't think it is too bad..depending on the price. Filters are all over the place as far as filtering efficiency. One is 15 microns at 98%, another is 20 microns at 99%, another is 25 microns at 97.5%. The key is none of them have the same numbers. You would need to know what they all do at say 99% to get an accurate comparison.
Buy one of the better filters and you can't go wrong.
Old 01-13-2012, 05:35 PM
Cobra Make, Engine: Everett-Morrison
If you are looking for maximum filtration of about less that 1 micron, Amsoil may have what you are looking for: AMSOIL - By-pass Oil Filter Mounting Kits
Old 01-13-2012, 07:03 PM
Cobra Make, Engine: jbl
think i'll stick with mobil 1.
there, we covered them all
Old 01-14-2012, 06:47 AM
Dwight's Avatar
Smile Oil Questions
What is the bypass rating?
Relief valve opening pressure?
Does the bypass opens at 14 psi allow the oil to bypass the filter? Then how much oil is really filtered? If our motors have 50 psi on the oil system how does this work?
I understand that the manufactory build a bypass into their filters because people do not change the filters and they clog up stopping any oil from passing thru. Thus lawsuit for a new motor, because I to dumb to take care of my old motor!
Dwight
Brand Motorcraft
Manufacturer's Part Number FL1A
Part Type Oil Filters
Product Line Motorcraft Oil Filters
Summit Racing Part Number ACF-FL1A
Oil Filter Style Canister
Height (in) 5.190 in.
Outside Diameter (in) 3.780 in.
Filter Bypass Relief Valve Yes
Relief Valve Open (psi) 11-14 psi
Anti-Drainback Valve Yes
Smallest Particle Filtered 20 microns
Maximum Burst Pressure (psi) 200 psi
Thread Size 3/4-16 in.
Gasket Outside Diameter (in) 2.800 in.
Gasket Inside Diameter (in) 2.422 in.
Gasket Thickness (in) 0.203 in.
Quantity Sold individually
Brand Motorcraft
Manufacturer's Part Number FL1HP
Summit Racing Part Number ACF-FL1HP
Height (in) 5.750 in.
Outside Diameter (in) 3.719 in.
Relief Valve Open (psi) 22 psi
Gasket Outside Diameter (in) 2.813 in.
Gasket Thickness (in) 0.328 in.
Quantity Sold individually.
Old 01-14-2012, 10:49 AM
Bypass iPreuusure is differential across filter. Most at operating temp has diff pressure across filter less than 1 psig. Even at40f only 2 or 3 psig.
Old 01-14-2012, 10:55 AM
You would always prefer bypass over oil starvation so go with lower bypass, most are 9-11psig. Good thing about FL-1A style filters is they are clean side bypass, most are dirty. I have never seen anything over 3psig differential across mine, I had some gauges before and after and did extensive testing. Royal purple has syntheic media, wire mesh maintaining pleat spacing etc. they actuall sent their filtration charts to me including flowrate vs pressure drop. at 8 gpm they are like 3 psig at 212F 10W30. I thing motorcraft FL-1A was 6 psig.
Old 01-14-2012, 01:10 PM
Cobra Make, Engine: FFR #4227, 302; About to take delivery on B&B Street Coupe (Daytona)
Maxx;
Enlighten me on this. How could you have a clean side bypass? Doesn't the bypass allow oil to bypass the filter from the input side to the output side when the pressure drop is higher than rated?
Thanks,
Lawrence Perry
Old 01-14-2012, 01:11 PM
fordracing65's Avatar
We need an oil filter poll.
PRIDEnJOY
Old 01-14-2012, 02:49 PM
Clean side bypasses without going across the dirty side of the filter, oil enters and discharges to clean side most discharge via a button on bottom of filter look in some you will see it, you flush you dirty oil right to the clean side. Once again most never bypass so it's a non issue
Old 01-14-2012, 03:33 PM
Zoom This's Avatar
Wix....if it's good enough for Top Fuel teams and NASCAR it's good enough for my car.
Old 01-14-2012, 04:16 PM
Sorry zoom to much alcohol last night
Fuk that, top fuel run .25 mile wow, grow a brain, or turn off tv
QUOTE=Zoom This;1170817]Wix....if it's good enough for Top Fuel teams and NASCAR it's good enough for my car.[/quote]
Old 01-14-2012, 04:56 PM
Oil filter poll?
PRIDEnJOY
Old 01-14-2012, 05:20 PM
[/quote]
how bout fram?
Old 01-15-2012, 01:27 AM
Ant Ant is offline
Default Oil filter
Racing oil filters like Wix generally filter down to 60 microns as flow is more important in a race engine that maybe pulled down after a couple of race meetings than fine filtering. I wasn't keen on that so went for a Canton oil filter who claim 45gpm flow and filtering down to 8 micron with their microfiber filter element also I can screw on a normal HP4 filter. Cantons microfiber filter element appears to have better filtering capabilities than paper elements.
A J. Newton
The 1960's rocked!
