| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
01-31-2012, 11:06 AM
OH
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Fuel compatible sealant?
My gas tank filler tube is welded to a plate that bolts to the top of the tank. I've tried making gaskets out of cork and rubber, but I just can't seem to get the thing sealed. What sealant should I use that won't melt from the gas fumes/contact?
thanks,
Pete
01-31-2012, 11:30 AM
Ca
Is it an oval shape. Like what is use on most fuel cells approx 6"x 9 "? Mr Gasker & Fel Pro and others make a gasket for it. If not as described check with Circle Track Supply vendors. If it is a one off (home made design) use thin sheet cork and use a leather or rubber punch to create necessary bolt holes.
Amazon.com: ATL Racing Fuel Cells TF467 Heavy Duty Gasket: Automotive
Rick
01-31-2012, 11:31 AM
Full Blown Member
PSB,
Permatex Aviation Sealant "Form a Gasket". That stuff works. Just apply it on your connecting surfaces (metal, cork, any combo). Never used it on rubber actually but I have on cork and aluminum and it sealed perfectly. It was also submerged in gas and was not a problem.
rodneym
01-31-2012, 11:32 AM
Ca
Is it an oval shape. Like what is use on most fuel cells approx 6"x 9 "? Mr Gasket & Fel Pro and others make a gasket for it. If not as described check with Circle Track Supply vendors. If it is a one off (home made design) use thin sheet cork and use a leather or rubber punch to create necessary bolt holes.
Mr. Gasket 675 Fuel Cell Gasket - Car/Truck/SUV Parts
Rick
01-31-2012, 11:38 AM
OH
It's a rectangular hole. The tank is custom that came with the kit from Hunter Kit Cars. The permatex stuff is probably what I'm looking for.
Thanks,
Pete
01-31-2012, 12:04 PM
ca
Cobra Make, Engine: Hurricane Motorsports, 427w
I used Permatex Motoseal on my tank. Tow years and no leaks.
[url="http://http://www.permatex.com/products/Automotive/automotive_gasketing/specialty_gasket_maker/MotoSeal_1_Ultimate_Gasket_Maker_Grey.htm"]
Hurricane Motorsports #1053; 427w
01-31-2012, 12:26 PM
OH
A search for the Permatex Aviation sealant took me to Aircraft Spruce (duh! why didn't I think of that to begin with...). They've got a bunch of different fuel tank sealants. I think my tank is primarily leaking through the bolt holes, so this should work:
AEROLIFE POLYPROTECH FUEL TANK SEALANT SINGLE COMPONENT from Aircraft Spruce
Pete
01-31-2012, 12:31 PM
Originally Posted by rodneym
PSB,
Contact with gasoline will soften it. I tried it on the neck of a fuel tank and it leaked within a month.
Motoseal is the correct sealant to use. Like Matt, no leaks after a couple of years.
Jim
01-31-2012, 12:50 PM
OH
OK, where do you buy Motoseal?
Thanks,
Pete
01-31-2012, 01:07 PM
Thanks,
Pete
Pete, Seal-All. See this thread Brake Fluid Resistant Sealant for Girling Reservoirs it's even impervious to brake fluid and it's easy to find.
01-31-2012, 01:26 PM
Thanks,
Pete
Any auto parts store should have it. Seal-all works as well but I prefer Moto-seal because it stays flexible once it sets up unlike Seal-all.
Jim
Cobra Make, Engine: SPF#0760
Something maybe easier to find is:
Permatex® Hylomar® Universal Blue Racing Formula Gasket Dressing & Flange Sealant
Non-setting and non-hardening at elevated temperatures. It withstands rapid changes in temperature and remains flexible and tacky even at high temperatures, allowing repeated disassembly and reassembly in high performance applications. This no-run formula seals surface imperfections on machined flanges and is vibration resistant. Temperature range of -60°F to +500°F (-50°C to +260°C); resists engine fluids, including water, coolant, gasoline, lubricating oils, kerosene and some refrigerants.
Suggested Applications: Thermostat housings, differential coverings, hydraulic drives and motors, gearbox assemblies, intake manifold assemblies, oil, fuel and water pump housings and seals, fuel injectors and fuel pumps, transmission and torque converter seals.
SPFWiringDiagrams@Comcast.net
01-31-2012, 01:28 PM
OH
Originally Posted by patrickt
Great! I was resigned to having to mail-order something. I'll give it a try.
Pete
01-31-2012, 01:47 PM
Pete
If I were them, I would change their labeling. It really has the "As Seen on TV" look and is kind of gimmicky -- but the stuff really does work. I think if they made it look "more industrial" people might believe that it really does what it says it does.
01-31-2012, 02:20 PM
Full Blown Member
Agreed. The 'look' begs the question, "what does this stuff do that Permatex hasn't nailed?"
rodneym
01-31-2012, 04:23 PM
OH
Product placement apparently  . I checked the local Autozone, O'Reilly's, and Advance. They all had Seal-All, but none of them had the Permatex Motoseal.
Pete
01-31-2012, 07:58 PM
Ca
Lack of availability might be caused by anticipated liability if misused by average wrench. Go figure.....
Rick
02-02-2012, 05:40 AM
AZ
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
SEAL-ALL is the best and they sell it everywhere. I tried everything to seal my gas tank, nothing worked until I made a heavy paper gasket (Auto Zone -gasket kit) and Seal-All. It's been perfect for 4 years now..no leaks. I even use it on a "pesky fuel leak' at my gas filter canister top bolt...stops it everytime. In fact I carry a tube in my tool box to help my friends with fuel leaks....HEEE!
Give it a shot!
02-02-2012, 05:43 AM
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Same here on the Seal-All. Used mine with a cork gasket on a gas tank leak that wouldn't stop no matter what I tried.
3-1/2 years later and no leaks. (knock on wood)
Dan
