| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
03-13-2012, 09:10 AM
CA
Cobra Make, Engine: Kirkham KMP500 LeMans- Roush 451 Shelby block; KMP Flip-top with cammer: KMP 289 Bronze under construction.
Spinner Failure - Video
While autocrossing this weekend, I had a spinner malfunction. This was on the last session of the day. The safety wire and hub pin did not hold. It could have been much worse. I use the same set-up when I'm driving 120+.
NOTE: The wheels and spinners are aftermarket parts. This incident was and NOT a failure of Kirkham components.
Click here of Video and Photo's
03-13-2012, 09:52 AM
tx
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
Can you say ouch?! Glad it wasn't worse and at a higher speed. Did the spinner back off or crack and fail? The threads are pretty galled up. How are the pins on the hub?
Glad everyone is alright. Testament to the Kirkhams, the car didn't have more damage than it does.
Looks like the fender held the tire pretty well.
03-13-2012, 09:58 AM
NH
Glad you are safe!
Did you tighten, safety wire and be sure all was in the right direction?
Hmmmmmm
03-13-2012, 01:38 PM
Too much play between the spinner and spindle
N2Venon I didn't see the inside of the spinner but the spindle threads are stripped. I have 3 thoughts on this failure
The spinners where not retighten after every run. You have a heat cycle, metals expand and retract. This is the reason safety checks are done at events. I think if you pulled on the wheel top and bottom you would have gotten a rock motion. Just because you have safety wire in the spinner doesn't mean that the spinner doesn't loosen. It's not a sure thing
Is it possible that the spinner is not stainless or weak aluminum? The hub could also be the same thing.
Gald car was not heavily damaged and you where going 120+ mph.
If you are going to stay with spinner, I have found that with a 4 pound plastic dead blow hammer you can tighen up spinners after every run when things are hot. I am a little surprised that the car was not funny in the rearend before breaking. Either a wobble, small vibration, should have felt it in your butt. I know guys who run nuts for there wheels and have 500ft of torque on the nuts and safety clips.
Any time you have the cobra on a jack, check the front and rear tires for play. this could be loose wheel bearings, loose spinners, rear hub housing bearings or end play too much. tierod ends, inner or outters. Rick L.
03-13-2012, 04:57 PM
Ca
IMO it appears as though the threads in the aluminum knockoff were sheared. Initially perhaps by overtighening then pulled/cracked and sheared by the G force of the turns. The threaded hub is steel, the aluminum will be the first to fail.
Rick
03-13-2012, 05:00 PM
IN
Cobra Make, Engine: ERA 838
I am betting spinner failure. It came off really fast.
Be sure and post photos. Everyone that runs knock offs should be curious.
John
03-13-2012, 05:24 PM
IL
Could it just be anti-seize that you are looking at on the threads?
03-13-2012, 05:36 PM
Cobra Make, Engine: SPF#0760
I watched the Video about 5 times. Looks like the spinner came off under deceleration which would point to a loose spinner. Now if the hub was cracked or the spinner was cracked that's one thing. My guess is it was just loose. The safety wire acts as nothing but a tell tale visual indicator as to whether the spinner has moved since installed. I usually install the wire a bit loose so if it tightens up I know something moved. Don't believe overtightening is would cause this failure. It's not like you gorilla'd it on I'm sure. I would bet all whould have been overtightened in that case and I'm sure they were not. While any damange is unfortunate, it could have been much worse in a highway senerio...
Define aftermarket parts....maybe Trigo's and Vintage spinners? There are known limitations with intermixing wheels and spinners.
SPFWiringDiagrams@Comcast.net
03-14-2012, 06:15 AM
IA
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
That had to be quite a ride. I'm glad that you or a spectator were not hurt, and that the car wasn't seriously damaged. And it's very lucky that it happened at relatively low speed, on an autocross course, vs out on the public street with traffic, etc.
What brand of spinner and what brand of wheel? Is the interference angle between the spinner and wheel the same? Could there be a mismatch there?
I'd like see a determination made as to what actually happened so we can all learn from it and hopefully prevent it from happening to someone else. What do you normally do to check your spinners? Did you check the spinner before that run? At the start of the day? Do you use a lead hammer, or something else?
I know I visually check mine each time I go for a drive, and when I gas up. But not during a tour or something. I am definitely guilty of ignoring them somewhat. I have not autocrossed it, but I may. Your post should be a wake up call to all of us with a similar setup.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
03-14-2012, 06:52 AM
I have no idea what happened but over the years on this web site there have been many discussion on how to tighten the spinners. The people in the know say lead hammer period. Others argue that a soft blow plastic hammer is good enough and some will settle for nothing less than a Nerf hammer so as not to scratch the aluminum.
Go look at some old photos of the racing Cobras, they beat the crap out of the spinners with a LEAD hammer.
If you miss and hit the wheel rim you will do no damage.
THAT'S WHY THEY USE LEAD
SAAC member and supporter
Club Cranky charter member
03-14-2012, 09:38 AM
PA
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Wow, glad it wasn't worse. Thanks for sharing as we all need to stay focused.
That looks like a loose spinner that came off quickly (as they will with the stress of autocross). In my experience, only a lead hammer lets you know they are truly seated. You can feel and hear it as you whack the spinner it goes from tinney sounding to solid as it reaches the proper torque. You can not tell in the same way with plastic, deadblow, sockets, etc. Also, you need to give each wheel a test whack after each run. You would be surprised how they will loosen. X2 on the purpose of safety wire. If you depend on it to hold the spinner, you are just an accident waiting to happen. Please let us know what you find.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
03-14-2012, 10:54 AM
Ca
I have never seen THIS subject addressed: Were the original knockoff's from back in the day steel or aluminum?
Rick
03-14-2012, 11:11 AM
Cobra Make, Engine: Viking Blue "64" 289 FIA comp car by Superformance #0002, Keith Craft - 331 (460HP), Jim Inglese - 48IDA Weber carbs, BW T10 4spd.
Good question Rick, My guess is magnesium....
03-14-2012, 11:31 AM
ca
Cobra Make, Engine: SPF 239
Hey Darren,
Holy Crap man! I’m sorry to see that.
Now lets talk about the "spinner failure"…. it kinda looks like a "spinner installation failure"....?
You sure are giving that Aluminum a work out! Do you have an office and a permanent parking space in Provo? lol
Anyway, I’m glad to know you weren’t hurt and the damage looks minimal.
Jason
03-14-2012, 11:42 AM
Full Blown Member
I never would have thought they could be magnesium.
For what it's worth, and it ain't much  , I'd say steel.
Kudos to Darren for sharing. No matter who or what was at fault, it's probably not easy showing something like this publicly. Some guys are waxers (polishers) and some are drivers. Darren is both
On a side note, my Snake River Canyon jump will NOT be filmed.
rodneym
03-14-2012, 11:51 AM
ca
I agree completely and mean no disrespect to Darren. He sure certainly isn’t a “Poser” in my book….
Jason
03-14-2012, 04:19 PM
wa
I don't know positively, but I'm guessing aluminum.
Reason being that even in those days they were starting to understand the effects of unsprung weight on a suspension system. Since it's about a 3 to 1 ratio between steel and aluminum, I would be surprised if they were steel.
John Hall
03-14-2012, 06:04 PM
AR
Good question - I think the spinners with my Vintage knock offs are some sort of aluminum. Knowing how easy it is to gall and strip regular fastners in aluminum heads and intakes I've wondered about their durability and beating on them. My Corvette knock offs have chome plated steel knockoffs and as long as there is a little anti-sieze on them I can beat on them all I want.
