1Likes
08-07-2012, 04:34 PM
IN
Cobra Make, Engine: ERA 838
Floor mats won't stay in place
 My floor mats will not stay in place. I tried velcro, but it pulled off the carpet side in a few days.
What do you guys do?
I was considering using snaps on the back of the mats or using a plastic hook like used in the newer Corvettes.
08-07-2012, 04:40 PM
Order a set of the Mat-loc clips. A fellow Cobra owner gave me one and it works like a charm.
http://www.ggbailey.com/ggbailey/pag...ar-accessories
Doug
08-07-2012, 07:27 PM
Pin and Lift-A-Dots are what is correct.........
08-07-2012, 09:03 PM
I used plastic ties, one on each corner of the mat. I put a small hole in the mat with duck tape over the hole on the back then attached it to my seat frame. It never moves
08-07-2012, 09:16 PM
Cobra Make, Engine: SPF, Roush 427R
I do the same thing as Steve G. except that I put a grommet at the rear of the mat and use two interlocking zip-ties at both corners to account for the plane of the mat vs. the post. One could use a single zip-tie, but I have found this easier.
Tom
08-08-2012, 02:43 AM
Me
I used truck bed liner material with a couple of drain holes since the car is far from waterproof no sense in dealing with soggy mats all the time.The trans tunnel and behind the seats have the original type carpeting.
08-08-2012, 04:51 AM
ON
Mat-Loc clips work great!
08-08-2012, 05:09 AM
All new cars came out with something like this 1990-2004 Corvette C4 Floor Mat Retaining Clip after mats were pushed under the gas pedals
Dan Wulff
08-08-2012, 05:54 AM
VT
I've been using the clips from GGBailey for about 5 years. They work fine.
Tim
08-08-2012, 06:42 AM
Another method in addition to those mentioned. Glued to the underside of the floor mat the plastic runner mat material that has the grips, also stiffens the floor mat.
08-08-2012, 10:29 AM
I use two 5/16" hex head x 1" #12 stainless sheet metal screws. I thread them through the mat (right side/left side) into the carpeting up next to the seat. They hold terrific and are hardly noticable. Best thing is the whole shooting match costs less than 50 cents.
Too many toys?? never!
08-08-2012, 12:15 PM
Super Moderator
Yup...work great too.
Jamo
08-08-2012, 12:57 PM
Cobra Make, Engine: SPF2914 Sunset / Titanium
I currently use large industrial velcro, works great and use to remove mats to vacuum. In the past I have used bed sheet straps (from Bed Bath and Beyond) and clipped it to my mat and my seat frame.
Andrei
08-08-2012, 01:10 PM
I use zink plated 3/8"x1" cariage bolts and fender washers with holes down through the floor and my mats definitely do not move. I came 'way too close to whacking someone because the mat held my throttle open. Spincter time!
Karlos
08-08-2012, 02:44 PM
Jeff or anyone else have (1) pics of an original (for placement/location purposes), as well as (2) the best place to source these? A lot of good substitutes were shared her, but I'd like to replicate exactly how Carroll's shop did them (typed while putting away the glue gun, staple gun and two-part epoxy).
-Steve
08-08-2012, 02:58 PM
IN
Lots of great suggestions. I like the lift a dots, the Corvette part and the Mat-loc. I am going to think about this and make a decision.
Thanks.
08-08-2012, 07:19 PM
MD
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Go to your local hardware store get some snaps like they use on canvas. Pot one into each corner of the matt and screw the other half into the floor, snap the matt into place! mine have been in place for almost 17000 miles drag strip, road coarses and Tail Of The Dragon and all the rest of the twisty roads! Plus no peg sticking out like the lift a dot, and much simpler to install in matts.
B i l l
08-18-2012, 08:28 AM
IN
I used Lift-a-dot for the fix. They look the most correct to me. The post are clinched to the carpet instead of screwed into the floor.
08-18-2012, 06:27 PM
I too have the lift-a-dots and pins in my Kirkham and they work great.
Flip
08-20-2012, 05:00 PM
Super Moderator
I no like spammers.
Jamo
