December 2025
Old 08-19-2012, 10:03 PM
Default Which Valve Guide Seals?
I am going to replace the valve guide seals in my 427, Dart block, Roush SRTW engine. However, when I look up valve seals at the local parts stores, there are a multitude of guide and valve stem sizes to choose from. What is the best way to determine which ones will fit my particular heads? Should I just measure the guide and valve stem diameter when I take the valve springs off and then order the seals? Take one of the originals to the parts store? Or is there a standard size I should be considering?
Jim
Old 08-20-2012, 01:20 AM
Gaz64's Avatar
Measure the guide o/d, the valve stem o/d, the valve guide height (protrusion out of the cylinder head), valve retainer to valve seal clearance at full valve lift, and valve spring inner diameter. Go for viton before teflon.
Gary
Old 08-20-2012, 08:04 AM
Cobra Make, Engine: spf 2112 *427 stroker windsor
go viton seals
