November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By ERANJ
Old 01-18-2013, 06:11 PM
Default 427 Side Oiler Identification Help
I'm looking to acquire a 427 Side Oiler engine that I looked at today. Any information is appreciated. The engine has the following:
66-427 in rear with a scribed V
Date code is 2F20 - June 20, 1972?
352 in front of block
Ribs on both sides
No other casting numbers I can see
Has intake so cannot determine if it has 66-427 in lifter valley
Seller doesn't belive it has the oil provisions for hydraulic cam
Seller also states its a higher nickel block
Also that its a NASCAR Block (Can a NASCAR block have a 72 casting date and ribs?)
Has 4 holes for motor mounts I believe
Thank you in advance
dls141 likes this.
Old 01-18-2013, 06:39 PM
xlr8or's Avatar
Screw in freeze plugs?
Casting code next to the oil filter boss?
Pictures?
Old 01-18-2013, 07:03 PM
Screw in freeze plugs.
Date code above oil filter
Old 01-18-2013, 07:39 PM
ERANJ,
I have a ribbed side-oiler block date-coded similarly to yours. Mine has the hydraulic provision cast in it.
David
Old 01-18-2013, 08:17 PM
Bernica's Avatar
Senior CC Premier Member
As said before, pics will help. If possible, with the engine upside down and the pan off, from both sides and in the guts. Get the numbers on the crank and rods if you can as well. Also, scrub just above the oil pump and get that number.
Old 01-19-2013, 06:44 AM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Thumbs down
Sounds like a 427 service block to me. Not a true 66 NASCAR block. a true NASCAR block is designed for a flat tappet cam not a hydro cam. Also it would carry the block ID #'s C 3,4,5,6,7 AE-H stamp with the bullitproof versions being the 5, 6, or 7. Example C6AE-H. After 1967; 427 metal & casting procedures changed. I suggest you do some more reading b4 you buy. A "C5, C6 or C7AE-H block in premo shape/not repaired will cost in excess of $5K for the block alone if you can find one. That being said, the service block is ok. I just wouldn't plan on hitting 7 grand on a well built service block to many times! Good luck.
Old 01-19-2013, 10:23 AM
philminotti's Avatar
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Service block.
High nickel...not.
Old 01-19-2013, 03:13 PM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Royce Peterson is the guru supreme on all things FE.
Www.mercurycougar.net is good way of contacting him.
He and Jim Pinkerton should answer all you want to know.
If it has provisions for hydraulic lifters, it is a very rare 1968 only W code 427 or a service block.
There were no atheists in the foxholes.
