Old 05-18-2013, 12:56 PM
Cobra Make, Engine: SUPERFORMANCE #2258 402 S/R -ROUSH
Default Smith speedo ?
Hi guys , I have a Smith reverse speedo . The mph works but the odometer doesn't work . I tried turning reset knob while when car in motion but NG. I notice that knob can be pull down. Whats wrong. We're can get repaired or should just replace the hole unit. We're can I purchase one. Also how does dash panel come off on superformance. Thanks Kennyh
Kenny
Old 05-18-2013, 01:26 PM
Obsessive's Avatar
Cobra Make, Engine: Shelby American, 1965 427 FE, alloy MR heads, Sidewinder intake
Here's a resource for replacement and loads of experience to help you sort yours out, if possible:
Smiths Cobra Speedometers, Tachometers, Small Gauges and Clocks for Sale
Old 05-18-2013, 02:10 PM
Nisonger sells and services Smith gauges. Right in Mamaroneck, NY.
Old 05-18-2013, 03:33 PM
VintageUpgrades's Avatar
Cobra Make, Engine: Auto Restoration and Service
If you plan on keeping the car for a while, get the electric version. As for taking it out, there are just two retaining nuts behind the speedo. You might find it easier to remove the tach first. The trip reset cable will pull straight out once the gauge is removed.
Mitch
Old 05-18-2013, 04:09 PM
fordracing65's Avatar
AGREED, the price to fix can sometimes be as much as the price to replace, it will probably break again, Smiths are know for that, get the electronic...
PRIDEnJOY
Old 05-18-2013, 04:18 PM
Speedhut (and others) also make GPS speedos similar to the Smith. Not legal everywhere, though.
Old 05-19-2013, 09:10 AM
Default Which brand?
Should I use smith electric or another brand? Will it just drop in,and using my cable from my smith mechanical speedo?
Kenny
Old 05-19-2013, 12:37 PM
Smiths electric. Remove the cable from the car. The gear hole in the trans can be plugged a few ways. Use a plug from Tremec or pop in a freeze plug. When you order the speedo, order the wiring pigtail for the trans mounted speed sensor. It's not a hard install, but you will need some tall jack stands or a lift. You could pull the trans tunnel, but the adhesive on your # of car is fairly stout.
Mitch
