November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-11-2013, 08:51 AM
Cobra Make, Engine: B&B, 351W
Default Motor turns over hard after running!
This only happens once in a while.
The motor turns over hard and the car will barely start after a run to full temp. This will happen sometimes, even if the car has sat for a couple of hours or 10 minutes.
351 approx. 400hp. The cars always runs great, no other problems. Thanks for any ideas. This never happens after the car has sat overnight.
Old 08-11-2013, 08:55 AM
CHANMADD's Avatar
I nearly replaced a starter and put a new battery in .first...similar problems... And its back to perfect
again...
Old 08-11-2013, 02:20 PM
427 sam's Avatar
Cobra Make, Engine: Dax -fuel inj 383 chevy
Send a message via Yahoo to 427 sam
hi insulate the starter motor with a heat shield, you could be suffering heat soak through the wireing, regards Sam
Old 08-11-2013, 03:58 PM
BAsque1's Avatar
Steve:
I had the same problem and it was a multiple solution type problem, so far what they have said about insulating the starter it is true, however, you might need a high torque starter.
I changed mine and in addition it is well insulated, check your gas lines and their proximity to the engine you might want to insulate them as well.
I installed a 1/2 " phenolic spacer for the carb, I changed the gas filter and ensured that my air filter was the appropriate one as well.
How is the engine temp, optimum temp is bout 180-190* if it is over than that you might want to check your coolant, I use Prestone less than 50:50 ratio plus water wetter. Open road I am doing 180-185* short and stop 200* that's when my fans kick on. This is just to start with. I hope that this gives you some ideas .
Sincerely
Lou
PS
Make sure that you are not over boiling the gas and emptying the carb bowls when the car is turned off.
here is a link to the responses I got
Hot engine hard to re-start Vapor Lock???
Basque1
Old 08-11-2013, 07:41 PM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
Do you have a large ground wire from the starter bolt to the frame or back to the battery? That has fixed hard hot start for quite a few people.
Steve
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
Old 08-12-2013, 05:06 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
There are a lot of things that can cause this problem. I would start with the cheap and simple things. Check the wire connectors; both at the battery and the two large grounds to the chassis (battery and starter) Clean, tight and paint/corrosion free connections work best. How about the battery? How old is it? Have you had it load tested? How about the charging system. With the car running, you should be at 13.8+V at maybe 2500RPM. What is the voltage on the battery in the morning before you run it after sitting all night? Same as when you parked it the evening before? How old is the gasoline? Winter blend fuel can be a problem as can old fuel/cheap fuel.. Finally, get the car hot and park it and raise the hood. Does that make any difference in the starting behavior?
SPFWiringDiagrams@Comcast.net
Old 08-12-2013, 06:59 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
If you can get to the cables from the battery and starter replace them all with the biggest and best quality cable you can find. Check with your local battery stores. Many of them will make up a set of cables with the appropriate terminals and lengths you'll need. Take the old ones in with you so they can make up the correct length.
Two of our club members have had the same problem and the re-manufactured cables have cured both.
X2 the clean terminals and connecting points.
DonC
Old 08-12-2013, 01:10 PM
....maybe a little too much timing?
Old 08-13-2013, 02:55 AM
Gaz64's Avatar
+1.
What timing are you running at idle?
Gary
