November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-25-2013, 12:11 PM
Default Spinner retainer safety clips now standard equipment
Vintage Wheels is now including our unique spinner retainer clips as standard equipment on all wheel /adapter/spinner kits and also adapter kits.
The clips are spring stainless steel - a great fail safe device for added security ,spinners should still be tightened with a lead hammer and safety wired.
Please note the clips can be installed with or without the adapter end cap in place - see link below
1 x set adapter/spindle safety clips : Vintage Wheels, Hot Rod and Muscle car
Hey competition drivers - some organizations are making retainer clips a requirement!!
Bob Lacey
Old 08-25-2013, 02:04 PM
Mother's Avatar
Cobra Make, Engine: Boss Replica Motors BB 460 by New Generation Engines
I guess that this is supposed to be better than the safety wires being used now? Is it better with the clips?
Old 08-25-2013, 03:46 PM
fordracing65's Avatar
How do these compare to the Kirkham setup???
PRIDEnJOY
Old 08-27-2013, 09:09 AM
Hi Mother
the clip is fail safe device -it will prevent your spinner coming off , you should still safety wire .
Ford Racing 65
The Kirkham set up is a spring loaded mechanical device that works automatically ,our clips are inserted manually and can be retrofitted to many hub spindles.
Bob
Old 08-27-2013, 09:48 AM
Can you please describe the process for installing these?
Old 08-27-2013, 10:05 AM
Cobra Make, Engine: Superformance #678
My guess is you have to drill holes through the threaded hub to install the clip.
Old 08-27-2013, 10:41 AM
Yes unless you have Vintage adapters which already have the 1/8 inch holes.
I will we posting a series of photos on our web site in the next few days
Bob
Old 08-27-2013, 11:20 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
A great and sensible idea, Bob--I'll be ordering a set soon.
Old 09-04-2013, 05:40 PM
Default installation procedure
Hi All
As promised here is a link to the install procedure with photos
Spinner Safety Clip Installation : Vintage Wheels, Hot Rod and Muscle car
Hope this helps
Bob
Old 09-10-2013, 02:27 PM
I looked at my wheels last night and the front face of the spinner is almost flush with the top of the hub threads. So I don't think there are enough exposed threads to install these even if I wanted to.
Is a properly installed spinner with safety wire adequate, or do I need to figure out some sort of retaining device, like this or the Kirkham set-up?
Old 09-10-2013, 02:31 PM
The wire is fine, this is just added safety...
PRIDEnJOY
Old 09-10-2013, 02:54 PM
Cobra Make, Engine: 427
I personally like the look of the wire tie and I've never heard of one failing in our application,
what's surprising to me is that there is quite a few other 60s cars jag,ect. that have knockoffs with no wire tie or other safety it all.
