Like Tree1Likes
  • 1 Post By Cashburn
Old 01-17-2014, 01:17 PM
Cobra Make, Engine: SUPERFORMANCE #2258 402 S/R -ROUSH
Default Ceramic Side Pipes?
Hi Guys, Is there any way to give the side pipes a little shine? There a little dull. Its tough being me ..
Kenny
Old 01-17-2014, 01:45 PM
Cashburn's Avatar
Backdraft Racing Dealer
Mother's Billet Polish or something comparable.
Ono cobra likes this.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 01-17-2014, 03:08 PM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
If they're ceramic coated silver try four O steel wool with aluminum polish. That's worked on mine for the past 9 years. The 4 O wool is softer than the aluminum matrix they use in the ceramic so it doesn't hurt them.
DonC
Old 01-17-2014, 05:07 PM
bobcowan's Avatar
In order to make something shiny, it has to be smooth. Try careful wet sanding with some 2,000-4,000 emory paper. Then use some Mother's polishing compound with a power ball. You'll get a nice shine that will last.
Be very careful with the abrasives. The ceramic coating is not that thick to begin with. And the thinner it is the less effective it is. Be sure to use a sanding block. Don't spin the power ball too fast. It will quickly burn right through the coating.
Practice on the bottom of the pipe, near the tip. If you burn through there, it won't matter that much.
Don't bother using any kind of wax or polish like you would on a painted surface - they can't handle the heat.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
