73Likes
08-17-2014, 07:11 AM
I just want to say congratulations !! You have created a beautiful and elegant breed of cobra and from what I have seen here it's nothing less than spectacular!
I'm already drooling on what I see in your last set of photos and even with the little chrome you have on now the lines and color are just perfect!! Can't wait to it when the windshield, bumpers and the other chrome hardware are installed.
08-19-2014, 06:11 AM
Ron - If you have gotten to this point, did the fender revisions require any trimming of the front or rear wheelwell bulkheads?
08-19-2014, 07:22 PM
Cobra Make, Engine: ERA 148 Nightwatch Blue
Dan the front panels will not need to be trimed but since the rear quarter now have a totally different shape, a new template will have to fabricate and then transferred to the supplied ERA aluminum fender bulkheads and cut.
Eddie is already on top of that since he brought it to my attention even before we started the project. He has left no stone unturned and really did his homework on this one.
08-20-2014, 06:07 AM
Thanks. It's a big temptation for me to order a set of your rear fenders and go back to work on mine. But since I've just gotten it on the road I'm resisting so far. Looks great.
08-22-2014, 07:00 AM
Sooooo beautiful ! ! !
What a dream car.
Thank you and Eddie for making this happen.
Well worth the wait.
Now, need to hit the lotto and this is the top of the list
Originally Posted by Metal-morphous
Since we modified the lower rockers a line of rivets would not look very good so I'm going to use a rivet 2 inches back from the front outrigger tube and another one 2 inches from the rear, then bond the rest of the tube with epoxy.
Chris and Academic
The photos really don't do this justice, you should see it in person,, so if your in my area in the next couple of days feel free to stop in and see it !! After that Eddie will have it back at his place in MA.
08-22-2014, 02:43 PM
08-22-2014, 04:06 PM
NC
All I can say is WOW!!! Beautiful job as usual.
John O
jjo42
08-22-2014, 05:11 PM
John I bet you say that to all the girls. :-)
08-23-2014, 04:35 AM
OR
Very pretty!
ERA FIA 2088
08-23-2014, 05:05 AM
Beautiful car and work by your shop. Congratulations. ERA should work out a deal to offer that as an extra cost option using your fenders from the molds.
08-23-2014, 06:56 AM
Thanks Dan,
We are looking forward to doing another narrow hip in January and it is another ERA.
Dan the attached photo shows how we bonded the body to the outrigger.
It worked so well we elected not to use any external fasteners.
The bonding product is SEM multi use panel adhisive.
08-23-2014, 04:17 PM
That's a nice detail. I ended up using countersunk 3/16 rivets on mine and a marine adhesive/sealer. Looks fine with the rivets flushed out and painted over but probably overkill. Looks like this may become a trend with ERA
08-24-2014, 07:04 AM
Eddie getting her strapped up and heading home. His tow vehicle is just beautiful !! A brand new Diesel powered Jeep Cherokee with all the bells and
whistles. I never herd such a quite engine and at over 400 foot lbs of torque for a 6 cylinder it has way more than enough pulling power.
Eddie said he will send post photos as he completed the narrow hip.
09-29-2014, 12:24 PM
Hi Eddie,
Hope very much that you got your charge home safe and sound.
It is too beautiful for words.
Please allow us an update, when you can
Thanks ! ! !
09-29-2014, 01:29 PM
Ersatzfknarf ,, I talked to Eddie yesterday and he had a few LARGE home projects he had to attend before getting back on his narrow hip project but he did spend some 8 or more hours getting the inner fender panels customized since they had to be trimmed to fit the new shape of the quarter panels
09-29-2014, 08:16 PM
MM,
Looks great! Seeing those Gray Jeep / solid Blue ERA Cobra tow photos coming home from the shop is a bit like DejaVu for me. My original color was suppose to be NW Blue but I tweaked it just a tad last minute. I remember the photos of that solid blue car you did 20yrs ago too.
Duane
09-30-2014, 10:22 AM
Hi Metal-morphous,
Thank you very much for the update
Very glad to know the car made it home safely.
Hope that the home projects will quiet down and allow Eddie reasonable quality time to focus on the important stuff
Looking forward to photos of the inner fender panel work
09-30-2014, 05:18 PM
Duane nice color:-)
Here's a couple of photos that Eddie sent me. His hours of inner panel fitting turned out real nice and he made templates which will come in handy for my next narrow hip project that we will be starting soon. The photo with the windshield install looks very elegant.
09-30-2014, 06:59 PM
rear end width
MM,
do you know if the rear end differential was the standard 54.5 or 52.5" narrowed width version for pin drives on the narrow hip car pictured? Are those 245/60-15s on the rear?
Looking at the photos I'm trying to understand if you think those tires will rub on the inside of the rear fenders or not once fully loaded and compressed. I'm making reference to another narrow hip car that I helped a friend with that came off an original 427 narrow hip mold. It was pretty close, less than 1/4 of clearance barely following the arch travel of the suspension. It would rub if the tank was full of fuel with driver/passenger. The fix was new springs and QA1s.
Duane
10-01-2014, 05:34 AM
Ma.
Cobra Make, Engine: ERA 427 Narrow Hip Street Roadster
When I assembled the xj6 rear I exchanged the half shafts and control arms with ERA. So it is the standard rear with inboard brakes that is used on ERAS. I was going to use an xke rear with ERA cage which is what was used on all early ERAs but opted for xj6 because of strength of stub axles. The first ERAs even used the xke cage. The tires are 245 70 series.Peter's advice. We jumped up and down with 2people in trunk with Spax nuts backed off to make sure of clearance. Close but clears. Ron did all body work with wheels and tires mounted to make sure of body clearance. The present ride ht. is set high for ease in sliding jack under during build.
