1Likes
04-17-2014, 08:37 AM
NM
Cobra Make, Engine: contemporary cobra
How to tell what manufacture mine is?
 Is their a way to tell what manufacture the cars are mine was registered in CA as a spl. it looks close to a ERA from pic,s it has a very thick body and is very well built has square tube chassis mustang II style front with tubular A-arm and fox body mustang rear suspension 4 wheel wildwood disc brakes I've looked at a ffr but mine is more round on the trunk .
Gear banger
04-17-2014, 08:59 AM
Need to post pics of the underside, suspension, engine bay, dash, trunk, and all four sides of the car.
ERA doesn't use Mustang II suspension or Fox rear suspension. Not an ERA
04-17-2014, 10:20 AM
Not an FFR either. Factory Five is a tube frame ( 4" round main tubes) with a lot of riveted aluminum panels and the body is a skin not a tub.
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
04-18-2014, 08:23 AM
NM
Gear banger
04-18-2014, 11:35 AM
NM
here's  a couple
Gear banger
04-18-2014, 01:14 PM
Do you have any info on when it was built? DMV records should show when first registered. Unless it was a DMV assigned VIN, the VIN may provide some here with a clue. Check around on the frame for some numbers also.
Is the wheelbase 90 inches?
Just some observations: It has kind of a mixture of 289 and 427 features. The forward braced roll bar and sidepipes coming UNDER the body are like a 289 instead of through cutouts like a 427 (although the 4 into 1 arrangement is like a 427). Kind of hard to tell exactly from the pictures, but the front wheel well flares look like they may be coming out a few inches down the fender like a 289 instead of at the top of the fender like a 427. May just be the picture angle though.
But then there are 427 specific features as well. The oval front grill opening (289 is flat on bottom), rear flares tapering into the body at the sidepipe exits (no taper on the 289), and fuel fill on the fender indicate 427.
I point these out in case someone knows of a manufacturer who combined features from each. Some other notes…The steering wheel has round openings instead of slots. Radiator and positioning, from a Mustang perhaps? Power steering. Louver positioning in close proximity to flare. Hood hinges.
This may help as well: Compare car profiles
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
04-18-2014, 01:56 PM
WI
Cobra Make, Engine: B+B 351w #112
LA Exotic ?????
04-18-2014, 02:40 PM
Still need pics of the firewall, frame, and trunk area
04-18-2014, 04:00 PM
NM
here is the trunk and firewall ill have to wait to put it on the lift for the under pick but the frame has a x where the trans. mount is.
Gear banger
04-18-2014, 04:18 PM
Registered User
Cobra Make, Engine: S C Motorcars
LA Exotic or S C Motorcars or B&B.
Lester
04-18-2014, 06:07 PM
NM
are they good cars it seems like its better than some that i have seen but im still learning?
Gear banger
04-19-2014, 05:33 PM
Fl
Cobra Make, Engine: 1965 Contemporary 427 SC. built in 1982 before CCX serial #. has body #106. engine 351-C with 48 IDA'S 500 hp, T-56 6 speed, Halibrands k/os. Featured in KIT CAR, MOTOR SPORTS MONTHLY, AUTO X, AND SPORTS CAR. Original owner/builder
manufacture
The Contemporary Cobra came with Jaguar IRS rear only. Front suspension was also Jaguar torsion bar, later coil over optional. They also had a 4" round tube frame.
Hope this helps.
Don
04-19-2014, 10:13 PM
Cal
Looks Like a L.A. Exotics to me, but it's been a while.
The hood hinges and footboxes are what I based it on.
04-20-2014, 07:53 AM
Senior ClubCobra Member
The door shape and hood latch aren't right for LA exotics.
04-21-2014, 07:11 AM
Cobra Make, Engine: SMC 67 Cobra/302
Could be an SMC. What does the vin plate show ?
04-21-2014, 10:32 AM
NM
its a ca spcl vin tag no manufacture
Gear banger
04-21-2014, 12:10 PM
OK
what are the first four letters of your serial number?
"Let's roll"
"Be part of Something Good
04-22-2014, 07:08 AM
NM
Ca50 are the first 4 on the vin.
Gear banger
04-22-2014, 12:27 PM
Rear quarters remind me of a NAF, they made a 289FIA version too.
04-22-2014, 01:17 PM
Registered User
S M C and S C are the only ones that used that type of hood latch and that boss for the hood bumpers.
Lester
