Old 07-25-2014, 02:42 PM
Cobra Make, Engine: SPF-small block stroker
Default Need a spacer
I am trying to locate a collector flange spacer for an SPF small block. I need one that is tapered 1/2" to 1/8". I called Craigs Cobras, and he is going to be out of pocket for awhile, and I am looking at 1mo or more to get one. He mentioned some one else who mentioned having one, but I did not catch the name.
If any one has one, or info for another source I could use a little help.
Thanks, excop
Old 07-26-2014, 10:27 AM
just a bump
Old 07-26-2014, 05:06 PM
Dwight's Avatar
Smile
check FFCars.com : Factory Five Racing Discussion Forum site.
They use a lot of tapered spacers.
1/2" is a lot.
are these the spacers between the headers and sidepipes?
Dwight
Old 07-26-2014, 05:14 PM
Senile Club Cobra Member
I have one of Craig's spacers in stock but not 1/2". That's a lot....perhaps there are other issues going on? Mu spacer is likely 3/8" on the thick side.
PM for details.
rick@autoventureusa.net
Old 07-27-2014, 12:03 PM
Thanks for your help guys. After looking at the problem from a different angle, I think I will lower the opening instead of raising the pipe.
This all started with different pipes, trips to the dyno, weekends at Hallett raceway, different tires, the typical Cobra sickness.
I have since moved, so no more Hallett. I have proved to myself I can go fast, so I think I will just cruise the curvy roads, and enjoy the car at a more moderate pace.
Old 07-28-2014, 04:48 AM
indianamoon's Avatar
Cobra Make, Engine: B & B 289
Default spacer
If you decide you need one, pm me and I will see what I can do. Just made one for my B&B and saved the programs. It is probably the same pattern.
Pat
Display Modes
