December 2025
Like Tree2Likes
  • 1 Post By mr bruce
Old 11-03-2014, 06:58 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Default Need help fabricating exhaust system
I need some guidance on how to route the 3" tubing where it transitions to the engine. The pass side looks relatively straightforward. The the driver's side has the master cylinders..
Thanks
Bill D
Old 11-04-2014, 04:24 AM
hi Bill, that's the problem with under floor pedals, packin' 10lbs of s++t into a 5 lb bag, there just ain't much room down there, you gotta run between the 4" main frame rail, and the 1st master cylinder, under the other 2 past the outter frame rail and then onto the side pipes, Spintec probably has what you need- Oval Tubing - Oval Elbows - Vertical Oval Elbows - SpinTech Performance Mufflers
Bill D likes this.
