Like Tree9Likes
Old 01-24-2015, 05:59 PM
Well then under what circumstances would any skilled FE builder choose a 4.125" stroke over a 4.250" stroke (not counting the specific request of the customer)?
One looking for higher RPM out of the motor
Old 01-24-2015, 07:30 PM
Dimis's Avatar
This guy... Every time I read one of his posts all I can do is face palm.
Old 01-24-2015, 07:27 PM
Dimis's Avatar
When he uses a dual plane intake vs a single plane
From what I've learned - It's all about the combination.
Old 01-24-2015, 06:22 PM
Patrick, if there was a displacement rule and a cylinder head rule, then you could opt for a shorter stroke. Sometimes we favor an oversquare situation because the larger bore will take advantage of the cylinder head/valve size.
AL, you have to be completely blind (or just have too much pride to admit it) to ignore the fact that there are 5.5" stroke engines that run at 9000 rpm.
Again, you can NOT use generalizations when speaking of engines.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-24-2015, 06:29 PM
No, no rule limitations involved. If you believe the answer is that there is never a reason that a skilled FE builder would opt for a 4.125" stroke (other than a race class restriction rule of some sort) then you should say so. Is a rule limitation the only time you can think of?
Old 01-24-2015, 06:43 PM
Rules...
Nostalgia...
Deck height limitations...
In a street car, I would rather have the cubes. I don't know why anyone would logically settle for a smaller stroke when the longer stroke rotating assemblies cost exactly the same.
In a race car, I would rather have the cubes. Pat Musi builds Mountain Motor class Pro Stock engines. They are 903-1000 cubic inch engines. They turn very high rpms and they are very undersquare.
In roundy-round applications such as dirt track racing, common engine sizes are 427-434 cubic inches. These engines turn 8000-9000 rpm, with the largest stroke they can fit in the block due to piston height constraints. These are applications where they require on/off switch style engine response. The stroke doesn't hinder that.
Jay Brown builds FE SOHC engines. He keeps increasing the stroke and I believe is up to a 4.600" stroke with a custom billet crank. He's approaching 8000 rpm with this engine and doesn't he use it in his Drag Week car?
I think we all may not still be on the same common ground as far as terminology and what's going through our minds. I'm still confused on whether we are comparing equal engines, or if we are comparing "potentials." I also think that some people's judgment may have been clouded by low compression, short cammed truck engines with 50 lb flywheels.
Old 01-24-2015, 08:12 PM
... AL, you have to be completely blind (or just have too much pride to admit it) to ignore the fact that there are 5.5" stroke engines that run at 9000 rpm.
But I can use generalizations as most cobra enthusiasts do not buy super trick builds costing upwards of $30K and more. What does that 5.5" stroker that revs to 9000 RPM cost? Better yet, what are the chances there is a member here with such a motor, slim and none.
That's been your problem with this debate all along, you fail to see that for the common enthusiast, certain general rules do apply and are totally applicable to the motors they consider for these cars. They are not exotic limited production builds that you continually reference as your "examples", that's just nuts, no one here uses them in these cars.
Here's the general reality for the guys that want to keep it reasonable in the motor department, and what they consider when making their decisions.
Bore to Stroke Ratio & Other Design Concerns
Old 01-25-2015, 05:00 AM
This discussion has not been about money, and you're well aware of that. Here, have another straw....
This discussion has been about your need to troll each thread that involves talking about crankshaft stroke, and inserting your completely incorrect generalizations.
And BTW, we all know that racier parts cost more. Did you end up using that Superlight crankshaft that you listed for your engine? If you want to talk about staying reasonable in the engine department, I would make the argument that you don't spend $1200 for a Superlight crankshaft in a low rpm, low compression street motor.
Old 01-25-2015, 05:14 AM
750hp's Avatar
It's not mine, but my good friend has put this 5.7" stroke motor into his street car. Sounds like it revs just fine for a pump gas street engine
Craig
Old 01-24-2015, 08:20 PM
RodKnock's Avatar
I disagree. I use them all the time.
Old 01-24-2015, 07:21 PM
Cobra Make, Engine: Contemporary Classics, red white stripes
Hi Barry,
There are plenty of reasons why someone would choose a shorter stroke in a street car. HP is important, but that isn't the only consideration for a hobby car.
Personally, I want a 427 so I don't have to explain myself at every gas station (why isn't it a 427?), and also because I have always wanted a 427 side oiler. It's weird. I know that a 427 and 428 perform about the same, but I still want a 427 side oiler. Everyone needs to own an icon at least once.
I can build a 4.25x4.25 side oiler, and I might. But I don't need the extra stroke. This is mostly a street car for me.
Btw, I agree with everything else you said about 428 vs. 427. I had a 428 in a Mustang about 15 years ago, and to this date, it was the fastest (and quickest revving) car I have driven. Other cars I have driven include Pantera, Viper, Ferrari, and a supercharged 5.0 Mustang. That isn't a long list, but they're not slouches either. My point is that my 428 had a 3.98" stroke, and it was scary fast. It revved much faster than my 93 Mustang Cobra, which had a 3" stroke.
Here's a better one. My Pantera had a stock 351C when I bought it. I rebuilt it and stroked it to 377". The 377 revved much faster than the 351C, and the only thing I changed was the crank, rods, pistons. It currently has a 4" crank for 408". I'm not quite finished with it, so I don't know how it will behave, but I doubt that it will run out of wind at the top end.
Old 01-24-2015, 07:24 PM
Hi Barry,
Old 01-24-2015, 07:40 PM
Dimis's Avatar
As to answering the topic.
If I had a 428 Id keep it... And only swap it out for a new fandangled aluminium jobs... Because yes... I'm an overweight weight weenie.
Old 01-24-2015, 10:24 PM
tmareina's Avatar
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
I have a 428 600+ HP with 11.4 compression dual 660 Hollies on a tunnel wedge. It sounds wicked but it's manageable on the street and a screamer on the track. 13,000+ miles without any problems.... Hope I haven't jinxed myself.....wouldn't have any other for the money. Tom Lucas did an awesome job.
Old 01-25-2015, 07:30 AM
RACERAL's Avatar
Cobra Make, Engine: Factory 5 mk4 445 FE
BangShift.com Mountain Motor: A Closer Look at the 1005ci - 2100hp Naturally Aspirated Monster From Sonny Leonard - BangShift.com
Thanks,
Al Adkins
Stoneville,NC
My ex car. Sad to see it go.
http://www.ffcars.com/POM/nov2003pom.JPG
Old 01-25-2015, 07:55 AM
2100 hp at 8000 rpm. 5.875" stroke. Someone forgot to tell Sonny that long stroke cranks can't rev...
Old 01-25-2015, 07:58 AM
Bernica's Avatar
Senior CC Premier Member
I guess "case closed"!
Old 01-25-2015, 08:11 AM
Yes, and just "a cool $115,000 shipped to your door!"
My uncle Bob in Iowa can make a tractor motor rev to 10K for $115,000.
But let's see those mountain motor cobras, must be an awesome sight eh!
Old 01-25-2015, 09:42 AM
Then you should have called your uncle bob and asked him about stroke and rpms, because he could have set you straight.
lippy and cycleguy55 like this.
Old 01-31-2015, 03:09 PM
mtrain2000's Avatar
Cobra Make, Engine: Shell Valley
Good one brent............
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
Display Modes
