Like Tree2Likes
Old 06-23-2015, 04:31 PM
Originally Posted by w-lewis View Post
I have a Unique and it's a bit tight getting in and out for us old farts, but I can manage it ok. I have a buddy who is a bit older and less limber than I am and he is interested in a Cobra, but I don't think he would be able to get in and out of mine, especially without burning his leg. I'm not too familiar with the other makes, but does anyone have a recommendation as to which car is easiest to get in and out of?
Here is a power lift seat that may make things easier...
Power Passenger Lift Seat Project
Old 06-24-2015, 05:21 AM
Cobra Make, Engine: ERA #448, 1964-427
Maybe this will help out. Concerned about burned legs, I wrapped my sidepipes (muffler area only) with exhaust manifold fibreglass tape from Summit, then mounted sidepipe covers from Finishline. After a spirited drive the pipes are warm to the touch, not hot enough to burn your leg. Made "The Boss" happy.........
Old 06-24-2015, 09:56 AM
Slick61's Avatar
I got snakebit on my first outing in my Backdraft, but never since... and I always caution passengers to "watch the pipes" when exiting. And I never leave my car out of site in public... ESPECIALLY while the pipes are still hot. The larger cockpit of the Backdraft IS nice, and tends to enhance ingress/egress... I believe Lonestar's have a chassis that's stretched even further.
R. Smith
Santa Clarita, CA
Old 06-24-2015, 04:35 PM
gunkk's Avatar
Neutral
why not fit heat shields?
motorhead finally found his motor
Old 07-16-2015, 10:48 AM
Cobra Make, Engine: ERA with a 428 FE that runs on pump gas, but has plenty of power.
I have the heat shields on my side pipes, and everything is ceramic coated.
All of the issues mentioned still exist, by a lesser degree.
I have still burned myself on the pipes that exit the car, ahead of the shields.
I was adjusting the carb.
Also; when I go to car cruises or shows, I never leave the car for the first 1/2 to 3/4 hour. Children can really get in trouble if you don't watch them!
I always help my wife out of the car, so we are sure that her legs do not touch the heat shields. (Still HOT) I like the welding blanket idea too.
Don
Old 07-16-2015, 01:10 PM
I have a removable steering wheel on my ERA that would make it easier to get in and out, though thankfully I can do it now without removing the wheel.
Old 07-16-2015, 04:18 PM
DanEC's Avatar
I don't know what color your sidepipes are, but I think a lot of people are deceived by theories that silver or white ceramic coatings are cooler to the touch and less likely to burn you. IR temperature guns are calibrated to read a flat black surface. They don't read light or reflective surfaces accurately. You believe they should be cooler but they aren't (at least not very much) and will fry your skin just like any other exhaust pipe or header.
ERA 782 Running
