Like Tree3Likes
  • 1 Post By 1985 CCX
  • 1 Post By CHANMADD
Old 04-17-2016, 11:01 AM
Bill D's Avatar
Default Trunk Latch Help
I have a Mr. Bruce 289 FIA body with his fiberglass trunk,pan on a modified FFR frame. I have the trunk,latch installed in the trunk, but no "latch pin" on which the trunk latch can grip to keep the trunk closed. Any ideas? Original design?
Bill D
Old 04-17-2016, 03:15 PM
LMH's Avatar
LMH LMH is offline
What kind of latch does FFR use? It's been a long time since I built one and don't remember.
Alba gu brąth
Old 04-17-2016, 03:23 PM
Bill D's Avatar
FFR uses a straight pin but their body and trunk aluminum is different. I'll find a pic. On mine the pin will have to be above the body as shown in the pic
Old 04-17-2016, 03:27 PM
Bill D's Avatar
Here is a pic of the FFR setup. See the difference between my trunk and the ste FFR?
Old 04-17-2016, 04:45 PM
1985 CCX's Avatar
Here is mine.
Pretty much like original.
Bill D likes this.
Old 04-17-2016, 04:47 PM
1985 CCX's Avatar
Another angle
Bill D likes this.
Bill D's Avatar
Thanks Jeff. I'll look to see if I can fashion something similar
Old 04-17-2016, 04:50 PM
LMH's Avatar
LMH LMH is offline
This is what your trunk uses for a latch?
Alba gu brąth
Old 04-17-2016, 04:55 PM
LMH's Avatar
LMH LMH is offline
Jeff's is pretty close. Here's an original. Not a very close up photo though.
Alba gu brąth
Old 04-17-2016, 07:11 PM
Bill D's Avatar
Yes, my latch looks like that. But my latch is located too high. I'll have to make something special.
Old 04-17-2016, 07:28 PM
CHANMADD's Avatar
So What I did was .......Get some threaded rod from home depot or.... Get a link of metal chain and weld the link lengthwise to the end of the threaded rod.
Get two nuts two big washers for your height adjustment and the vise and acetylene..to bend the rod. Once you get it right , get some nice leather and cover it .
Bill D likes this.
Old 04-17-2016, 08:33 PM
Bill D's Avatar
I discovered another issue (endless it seems) this time with the trunk latch arm. As it moves from locked to unlocked, the arm hits the body. Looks like I'll have to notch it like in the picture above. I've marked the body where it needs trimming back (black line) and where the hole needs to be made to allow the arm to clear (orange line)
Old 04-17-2016, 09:18 PM
LMH's Avatar
LMH LMH is offline
It'll just be more like original!
Alba gu brąth
Old 04-20-2016, 05:44 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
If you are building a FIA style car, consider using the bungy cord with 2 washers as a trunk lock. It's not like you will ever be parking is a commuter parking lot and need security.
SPFWiringDiagrams@Comcast.net
Old 04-20-2016, 06:05 AM
Blas's Avatar
Old 04-20-2016, 06:32 AM
Bill D's Avatar
I'm using the bungy cord setup, but without the latch, the trunk will bounce while driving around.
