31Likes
03-23-2020, 02:01 PM
Look forward to seeing this in the first person.....
03-23-2020, 04:40 PM
What are the cutouts on the top for?
Alba gu brąth
03-23-2020, 08:04 PM
areomotive install
this is the EXACT location it needs to be in a CSX car. it fits perfect
03-24-2020, 07:51 AM
va
I'm not sure that would work in Jeff's car, It's the wrong colour.
03-30-2020, 02:41 PM
va
All these fuel tanks need something to hold them in place.
Today's job, get fuel tank straps ready for powder coating, these are for 427 cars.
03-30-2020, 02:57 PM
Ne.
Looking great.
For your powder coating, I have a "Group Buy" from the company Jet-Hot. If you're interested let me know.
JET HOT- Group Buy, Sale ?
Kevin
03-31-2020, 05:14 AM
va
Originally Posted by FUNFER2
Looking great.
I will keep the coating option in mind.
I have a very good working relationship with the two companies I use local for powder coating.
03-31-2020, 08:22 AM
Ne.
Ok, let me know if you want to join. 👍
Kevin
03-31-2020, 08:55 AM
Keep in mind that the tank Craig made for me is a 289 tank, behind the seat and not under the rear.
The cut outs are for me to get around the extra frame support with the units PU and filler neck.
Gives dead space above once full up. I'll post on the 289 link when I get started
06-22-2020, 10:11 PM
OH
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
Hi,
I’m looking to replace my CSX 4000 series gas tank.
Looking to go without a fuel cell as I don’t track the car.
Could you send me some info on options, prices, and time frames for your tanks?
Thanks in advance,
Jon Trimble
Jon
06-24-2020, 03:44 PM
Originally Posted by BigGuy
Hi,
Im looking to replace my CSX 4000 series gas tank.
Looking to go without a fuel cell as I dont track the car.
Thanks in advance,
Jon Trimble
Craig is your man!
My 289 tank perfect and the 42 gallon 427 tank I bought a work of art.
I recommend highly
03-25-2021, 08:37 AM
va
Thanks Jeff.
Here we have a fuel tank just finished for a 289 street car.
03-25-2021, 01:31 PM
Very nice work!
Alba gu brąth
03-26-2021, 08:47 AM
Looks Great!
04-10-2024, 03:56 PM
va
Working on a fuel tank for one of my favorite cars, Jeff's red Hi Tech, ( soon to have a colour change) for the most part we are using the same shape of the old tank from the car.
We have added a little volume and some bead rolls to the bottom of the tank along the lines of the large original tank.
04-10-2024, 04:06 PM
va
We folded the front and rear sides, add the baffles then the top panel.
We are using the fill and pickups from the old tank as well as the fuel level sending unit, this way it should go back together with out issues.
Well that's the plan.
04-11-2024, 03:47 PM
Look forward to installing it into HTM111.
04-17-2024, 08:46 AM
va
Drain plug added, all set to go back into the car Jeff.
04-17-2024, 09:36 AM
BC
Needs rock protection!
Hi,
Looks great. On my previous cobra I had an aluminum tank made and ran it less than a year then a rock hit it at 65 MPH and cracked the weld, aluminum is brittle. What a pain to drip gas all the way home. Then nobody would fix/ weld it as it had gas in it. So eventually a shop filled the tank with argon and welded it for me. I installed second skin on the forward side of tank:mad
Now my F5 cobra has the mustang tank and shield!
Perry.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
04-17-2024, 09:46 AM
I look forward to installing in HTM111, will be a great addition and will serve as a great improvement in appearance/performance.
