November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree2Likes
Old 02-07-2017, 02:48 PM
Dimis's Avatar
Default Missed ya Bernica!
Who are you and what have you done with Bernica?
Yep, the boys are back in town.
Old 02-07-2017, 06:35 AM
I just use one of these to pour fuel in through the vent tubes until the bowls are full.
Uhhhh, twenty bucks for a plastic squirt bottle? I swear you CA guys are just dripping with money.
Old 02-07-2017, 09:53 AM
Default Bernica, you need to step up your game....
Bernica, if you want to step up to what the pros use, I just might be able to get you what I have.... Yes, it's a condiment bottle from Bob's Big Boy with a piece of surgical tubing jammed on the top. Note, however, that it is carefully labeled as to its contents. It don't get no better than this.
Old 02-07-2017, 10:51 AM
RodKnock's Avatar
Yes and we line up to pay $5 a cup for our Philz coffee too.
Old 02-07-2017, 11:41 AM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
Is the cranking required to fill bowls with a mechanical fuel pump sufficient to alleviate (even partially) an oil starved start.
Old 02-07-2017, 11:55 AM
It depends on how much oil has drained down in to the pan since you last ran the car. Other factors that can affect that rate, other than time itself, would be things like the position of your oil filter and lines, and the "clinginess" of your oil. Now, FWIW, when my car has been sitting over the winter months, sometimes five or six months, for the first fire-up of the year I will disconnect the ignition (not that it would start quickly anyway because the bowls are dry) and then I crank it until I see my oil pressure gauge needle bounce up a little, then I re-enable the ignition and try and get it to start. It always takes more cranking, and pumping the pedal, to get the accelerator pump to squirt, before it fires up. In years past, when I had never bothered to keep a Battery Tender on it, there has been a time or two when I just barely got her to start before the battery gave out on the cranking. I have never bothered to squirt gas from my bottle down the primaries, nor do I even own a spray can of starter fluid. But, if I had an electric fuel pump (which I don't) I would be extra-vigilant in bringing up a little oil pressure, before enabling the ignition, if the car had been sitting for months.
Old 02-13-2017, 08:18 PM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Do we have any reason in the world a few short cranks to fill the bowls is a bad thing?
Generally, if I go a week, usually about two 10 second cranks before I touch the pedal, then 2 full pumps and it catches. About 1/2 the time it might require another 10 second crank and 2 pump sequence to catch and allow me the feather the pedal until I get a clean, fast idle. Then it's just a few minutes until oil and water temps come off the peg and I can move off kinda slow through the neighborhood until I get heat in it.
The older I get, the faster I was.
Old 02-16-2017, 06:03 AM
DanEC's Avatar
I think it's kind of a personal thing. I just don't like spinning a motor with minimal oil pressure at the bearings after it's been sitting awhile. And it seems like there are more start, cough, die - crank some more - moments with this approach. I just like mine to fire off on the first touch of the key and immediately build oil pressure.
But a lot of people seem OK with cranking it for awhile and with modern clinging oils it seems to do no harm that anyone can probably prove. Different strokes.
ERA 782 Running
Old 02-16-2017, 11:07 AM
Cobra Make, Engine: ERA FIA #2064 BOSS 302 CSX2047 sold
I must be missing something. I have a Holley double pumper fed by a
mechanical fuel pump running at 6 pounds. Even after a month I just
jab the accelerator a few times and it starts immediately! Am I just lucky?
Old 02-16-2017, 11:25 AM
DanEC's Avatar
After a month - if you just get in, pump it twice and hit the key and it immediately fires - yes, you are lucky. Need to consider buying a few lotto tickets or heading to the track.
ERA 782 Running
Display Modes
