1Likes
05-15-2017, 11:52 AM
Ne.
LONESTAR OWNERS. will a 385 series engine fit ?
Still thinking of two engines, either another FE, or maybe,.......a 460.
I have a 2000 Lonestar and I built it with a 428FE, FE motor mounts of course, Tremek TKO 500.
I have a brand new FE scatter shield, flywheel, clutch etc.
If,.....I go with a 385/514cu. I'll have to sell of trade for 385 series parts.
Anyway, have any of you installed a 385 motor or know for sure, if these engines will fit under the hood ?
I was mad that with a FE ,the turkey pan will not fit ! (only thing I don't like with the Lonestar)
And with my 428FE, I had to machine the carb surface 3/8" when I changed the intake manifold from the Edelbrock RPM to the Air Gap.
So, I don't know if the 385 engine ?
I would need measurments of both blocks from the pan surface to the intake surface.
Faster and easier,.....I would like to find someone that has a 460 built, so measurments from the pan to top of the carb would be great.
Kevin
Kevin
05-17-2017, 04:42 AM
AL
How much clearance did you have under the oil pan with the 428?
I had a Lone Star with a fuel injected small block and I made motor mounts to drop the motor. 42,000 miles with no problems.
Dwight
Reason: sp
05-17-2017, 05:19 PM
Ne.
I don't recall, but after I installed new coilovers and shocks, lowering the car, the pan is at the lowest I want. I have no engine in it, so I can't measure it now.
Kevin
05-17-2017, 07:43 PM
Oh
Somewhere on this site there is either a picture, drawing, or link to one that shows the Modular 4.6, 351 W, FE, and 385 series. I think there were dimensions that would tell you how much taller the intake/carb flange a 385 would be compared to a FE.
05-18-2017, 05:13 AM
Ne.
Well,.....where is it !
Lol,....
That would help a lot. I'll do a search.
Thanks, ya olddog.
Kevin
05-18-2017, 05:14 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
There's a couple of them with 460s. That's the same block, right? Fitting the carb under the hood may be a challenge. One of the ones I've seen has an extra large scoop.
05-18-2017, 05:35 AM
OR
I goggled it
ERA FIA 2088
05-18-2017, 08:07 AM
SK
I had concerns with how low my pan was to the ground. I had a custom-made pan built by Armando's Racing Oil Pans. It has kick-outs on both sides, three-quarter-length sump and the bottom of the oil pan is 1/4 inch above the frame rails. Pan capacity is in the range of 11 quarts.
That's always an option - a custom oil pan could allow you to drop the engine further than you could otherwise. FWIW, my clearance issue is now the bellhousing, not the oil pan.
Brian
05-18-2017, 09:40 AM
Ne.
Same block, you mean the 385 series is a 460 block too, then yes.
Originally Posted by *13*
I goggled it
Thanks bud, that helps a lot !
I had the kick out pan by Canton, which is 8qts if I remember correctly. Maybe 9 ?
A dry sump system like on the sprint car or like the Vette, would be ok, but expensive. It would have to be a retro-kit.
How much did yours cost ?
Do you have pics ?
Ya, my flywheel cover hit the street one time coming out of a parking lot, and it wasn't that steep.....
Kevin
05-18-2017, 11:47 AM
SK
Do you have pics ?
No photos of pan in car, but I have these: https://goo.gl/photos/LV32eSaJ4uwCyRWY9
As you can see in the photos, I have 2 drain plugs plus a bung for the oil temperature gauge.
I was not charged any more for custom dimensions / specifications. Prices include pickup and windage tray. Price list is here: Road race oil pan
Brian
05-18-2017, 03:42 PM
Ne.
Looks nice.
For amount of oil with your 460 and this pan, did he say the amount and what dip stick to
use ?
Also, did you make the headers or did West Coast Cobras have them ?
Kevin
05-18-2017, 04:21 PM
SK
Looks nice.
use ?
I put the oil pan on a level surface (bottom surface is parallel to frame rails and almost perfectly horizontal to ground) and filled it to the level I wanted with water. I carefully measured the water as I filled it, so that was easy. Once the pan was installed I filled it with the same amount of oil, inserted the dipstick (generic dipstick from Summit Racing) and marked the dipstick at the level indicated by the oil.
I'm the 3rd owner of the car - the headers came with it and have not been modified by me. I believe they came from West Coast.
Brian
05-19-2017, 06:19 PM
Oh
Kevin,
Here is one of the threads I was remembering. It came up several times over the years.
Ford Modulars are enormous engines
I thought it had the 460 engine too. This one does not have dimensions, so it is of little use for you.
Here is a link to the ERA site with the drawing. Perhaps there is more information on their site. Sorry I was of little help.
http://www.erareplicas.com/427/img/3pro_front.gif
05-19-2017, 06:45 PM
Ne.
Wow, a Boss 429 shoe horned into a Cobra !
That motor is more expensive than the car.
Ah, no worries, what can I expect out of an old dog ! lol.....
Thanks for the link, I'll look forward to reading it.
Kevin
05-20-2017, 07:48 AM
Oh
One of the members on this site, has a 385 series with Jon Kaase heads - which are improved Boss semi hemi design. He races top fuel hydroplane boats and his handle kinda of has top fuel hydro in it, but I do not remember it exactly. He may be able to give some advise.
05-20-2017, 06:33 PM
Ne.
Kasse's Boss heads are amazing, so is the price.
Kevin
