Old 07-08-2017, 05:03 PM
Cobra Make, Engine: Kirkham, 482 Shelby / TKO 600
Default Installing a 352FE to get through inspection?
I am finally getting a plan together to finish my car. I have a fairly health Shelby engine but I am thinking about installing a stock FE to go through inspection. I can get a 352 complete that runs for $200. I figure the fuel system, cooling, exhaust can all to set up to the 352 and will work directly with the Shelby is installed. Any thoughts?
Thanks.
Old 07-09-2017, 05:34 AM
In CT, your biggest challenge will be getting the exhaust quiet enough (and you'll need heat shields over the side pipes). Emissions for a Composite Vehicle are pretty liberal. The only advantage of the 352 is a lower compression ratio (depends on the engine model) making it a little quieter.
Also note there's a minimum ground clearance, so you might have to crank up the spring adjustments.
