Old 08-16-2017, 04:46 AM
Cobra Make, Engine: unknown...need to find out
Default Classics Roadster Brake Pads/Frt Wheel Brgs??
have a Classic Roasters Cobra from Fargo , North Dakota built by
Shelby American in Los Angeles, Ca. I need front wheel bearings and new
brake pads front and rear. I need to identify the front and read pads used and also the bearings are for what model mustang II?????
The calipers look like older GM single piston calipers but i'm looking for someone who also has a
Classic Roadsters Cobra to tell me that they used in the build. Thank you
Old 08-16-2017, 07:33 AM
If the front hubs are Mustang II, there's only one set of wheel bearings with the stock brakes: A12/A13. They may have changed the rotors/calipers because the MII brakes were tiny (~10" diameter, I think). If so, the bearings might be different. Measure the rotor diameter first. You might look through the pictures on rockauto.com to match up to what you have and/or take your stuff apart to check on the part numbers.
Display Modes
