Like Tree1Likes
  • 1 Post By Blas
Old 08-30-2017, 10:44 AM
Cobra Make, Engine: ERA with a 428 FE that runs on pump gas, but has plenty of power.
Default Issue with hood prop rod falling out in windy conditions
hello, fellow cobra owners!
I have had my hood nearly slam closed during a car show on windy days on two occasions.
I was there both times, and caught it, but when open it is nearly 90 degrees and it would surely be a disaster if it fell.
I have devised a part which I keep in my glove box which blocks the slot in the SS bracket.
I would think that this would fit any ERA car, 289, or 427 models.
I just don't know how often this happens to people.
I could use feedback.
The part is aluminum and I made it in two halves on an EDM machine.
Don
Old 08-30-2017, 03:54 PM
There are two types of hood props on the 427: The early prop pivoted on the hood and locked into a box on the wheel-well.
The later style (also on the FIA) had the prop pivot from near the firewall and fit into a T-slot on the hood.
Which do you have? If the latter, if you put a little more (or less) bend in the prop, it will "stick" into the slot to prevent the sort of problem that you describe.
Old 08-30-2017, 05:10 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
There was a member here with a yellow Cobra who posted a photo of what he did (long ago). He used an O-ring as a tie-down for his hood prop rod. Added a small knurled knob to the fiberglass hood just above the hole and secured the O-ring to the rod. Then the hood was open he just looped the O-ring over the knob. it was ingenious......
Blas
TN Shelby Cobra likes this.
SPFWiringDiagrams@Comcast.net
Old 08-30-2017, 05:38 PM
1985 CCX's Avatar
Friend of mine uses a tip that mounts to a small ball attached to the hinge itself. Requires pulling the slip lock as I call it.
Really cool......
Old 08-31-2017, 05:19 AM
Ok, thank-you.
I have the version with the hinged prop rod on the hood.
there is a subtle bayonet slot in the box on the wheel well, but it isn't too deep.
I will try what you have suggested.
Thanks, again.
Don
Old 08-31-2017, 05:21 AM
Ok thank you for your response.
Sounds similar to what I have done.
On a fiberglass car, the last thing you want it the hood to fall down?
Don
