November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By Jim Coleman
Old 03-17-2018, 11:07 PM
Jim Coleman's Avatar
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Default Cobra Tie Bar For XKE Rear End Availability ?
Saw this photo and wondered if anyone knows if they are still available.
Thanks,
Jim
Old 03-18-2018, 01:42 AM
Cobra Make, Engine: Shamrock
Should be really easy and cheap to get these laser or water cut.
Just find a contact who has items regularly laser or water cut so you don't have to pay the minimum charge.
Old 03-18-2018, 05:09 AM
Here's one of many sources:
https://www.speedwaymotors.com/Jagua...lain,7739.html
Google is your friend...
Old 03-18-2018, 09:08 AM
Thanks,
I saw the ones Speedway sells, and even thought about cutting a stencil
on my vinyl cutter and sandblasting a piece of aluminum to make it.........
Easier to buy it -- if it's available.
Jim
Old 03-18-2018, 10:57 AM
It appears CWI Inc (original fabricators of that link) is defunct.
Jaguar IRS tie link..
and here
CWI Jag IRS parts
Domain is dead
C.W.I. - Suspension - Parts and Accessories
Old 03-18-2018, 12:09 PM
Karl Bebout's Avatar
Other than being pretty nifty looking, does this make improvement?
A few years ago, I helped a friend install a very nice, and pricy, Watts linkage that seemed to make his car just squat and get, on hard acceleration.
Karlos
Old 03-18-2018, 12:27 PM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I will be fabricating a rear bracket on my car that will locate from the rear LCA fulcrum shafts and a stainless plate that attaches to the diff side brackets to a vertical bracket at the rear that will attach to a cross member that I welded onto the chassis.
Because of the toe in adjustment on your car, the rear tie bar holes that are pre drilled by CWI in their tie bar may not align with the fulcrum bars on your car. Toe in is set using horse shoe shims behind the diff brackets. What is the rear width measurement of the rear fulcrum bars on your car?
I have a CWI tie bar that I won't be using for this reason.
I think my idea will add greater support to the rear of the LCA.
Old 03-18-2018, 01:42 PM
joyridin''s Avatar
I would look at doing something like this that links the shafts and the brackets together. If you want to stencil it, you can easily do it on the back, but nobody would ever see it. This is just a 1/4" aluminum plate that has been rolled and drilled to match the mounting holes and fulcrum shafts.
Old 03-18-2018, 01:54 PM
Thanks, Guys --
It was just something I thought looked neat, but if it's not seen
wouldn't be worth the effort.
Jim
Old 03-18-2018, 02:21 PM
Originally Posted by Jim Coleman View Post
Thanks, Guys --
Jim
I highly recommend the tie-bar. The brackets alone (bolted to the differential case) were never designed to take the full toe-stress from acceleration. That force was absorbed into the original sub-frame. In addition, as installed in the Jag (with trailing arms) the stress on the inner pivots is only about 1/3 of what it is without the trailing arms.
Old 03-26-2018, 10:04 PM
Thanks to CJ428CJ I now have a Cobra Tie Bar !
CJ428CJ likes this.
