| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
5Likes
3
Post By Tom Kirkham
2
Post By FatBoy
04-11-2018, 05:02 PM
TX
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Jag XKE Rear Trailing Arm Ideas?
I'm looking for ideas to replace the original "traction bars" (trailing arms) on my XKE rear end in my Arntz.
Would appreciate any suggestions.
Thanks,
Jim
04-11-2018, 05:43 PM
IN
Cobra Make, Engine: ERA 838
ERA uses rectangular tubing with different ends. You can see pictures on their web page.
John
04-11-2018, 09:31 PM
TX
Thanks, John
I thought about doing mine their way.
Jim
04-11-2018, 09:40 PM
IL
Cobra Make, Engine: Kirkham #259
What is the issue??
Is there a problem that you are not satisfied with??
Morris
04-11-2018, 09:53 PM
TX
No problems, no issues --
Just don't like the looks of the original trailing arms.
Thanks,
Jim
04-12-2018, 06:27 AM
FL
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Jim : Looks like you have a nice, well lit shop !
You didn't steal that rear end from that E-type in the background did you ?
What Grubby said, can't go wrong duplicating what ERA does. Or use round tube with heim joint ends instead of square.
What's the story on the E ?
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
04-12-2018, 07:07 AM
TX
Ted,
The photo came off the internet, wish my garage looked like that !
I have an Arntz; don't own a Jag.
Thanks,
Jim
04-12-2018, 08:33 PM
TX
Today I built 2 bars out of 7/8" solid bar stock, and added heim joints to both ends;
one with right hand thread and one with left hand thread on each bar. I made them 18"
long with a bracket that will attach to the frame. They remind me of the old Cal Track traction bars from yesterday.
Can anyone post a photo of their bars like this so I can see how the frame mount should fit? I need to see how the bars look with the weight of the car making the swing axles straighten out. As it is, with no weight on them they are droopy. I can't tell anything from a drawing.
Thanks.
Jim
04-12-2018, 09:15 PM
WC
Cobra Make, Engine: Shamrock
One of the neatest ideas I have seen on here are mini Watts linkeages mounted fore and aft on with center pivot the top of the Hub carriers.
04-14-2018, 06:45 PM
TX
I kept the bars simple so I could build them.
Ended up removing the coilovers and jacked up the wishbones so I could see how much
travel was needed, and got one side mounted today.
Got both sides done now, but didn't think the original coilover mounts I cut out of the cage were strong enough.
So, I rebuilt them out of 1/4" and I think that will hold up better.
Thanks,
Jim
04-18-2018, 12:28 AM
QLD
That lower trailing arm is so the rear doesn't twist itself up under load.
I can't see how you can heim joint both ends of the lower arm, unless you add an upper trailing arm as well.
Gary
04-18-2018, 06:22 AM
AR
One thing ERA does is mount the jag differential in a cage that has two mounting bolts at the top to the frame and allow the cage to pivot or swing fore and aft slightly. That allows the cage to "adjust itself" slightly as the axles and radius rods/traction rods cycle up and down with the lower control arms. Their radius rods are also threaded which allow a small bit of adjustment of the wheel placement in the wheel wells and of the differential yoke angle (side benefits).
04-18-2018, 03:22 PM
Originally Posted by Gaz64
That lower trailing arm so the rear doesn't twist itself up under load.
Gary
That should not matter. That trailing arm is mounted in the front of the lower control arm. All it does is hold the lower control arm from being bent back should you hit a pot hole or something.
Mine has the trailing arm coming from the rear to the outside fulcrum shaft. It has heim joints at both ends.
04-18-2018, 04:40 PM
CC Member / Sponsor
UT
Check out the rear suspension modifications on this XKE. Predator Performance makes very fast Jags.
1961 Jaguar XKE Lightweight-Style Racecar
04-19-2018, 06:50 AM
UK
Cobra Make, Engine: Kirkham #523, 427 S/O
I think the key to making the trailing links work is to have the forward heim joint on exactly the same axis as the inner suspension arm pivots as on the XKE that Tom linked to. Otherwise the suspension arms and trailing links are both swinging in unmatched arcs and the suspension with either bind, or something will have to give, neither of which you want.
Paul
