November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #21 (permalink)
Old 07-16-2018, 08:54 PM
eschaider's Avatar
The starter engagement issue is pointing to the problem. You need to fix that problem before the engine goes into the car or you will start using starters. BTW, when you fix the starter problem your TOB problem will also go away — w/o grinding on the clutch release fork.
Ed
  #22 (permalink)
Old 07-17-2018, 05:46 AM
I think Ed's right. We've had quite a few "broken teeth" threads over the years because of poor starter/flywheel engagement and this situation just seems ripe for that problem.
  #23 (permalink)
Old 07-17-2018, 11:03 AM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
I agree, except that I rang Powermaster Technical and they said 70% is ideal as it enables the pinion to fire back easily.
Can't say I agree with that at all. Especially turning over a big block.
So machine 1/16" off the front of the starter flange? Don't really want another $500 flywheel....
  #24 (permalink)
Old 07-17-2018, 11:50 AM
All of my Ford service manuals for FEs call for complete forward/back engagement on the ring gear and the depth must be greater than 1/2 of the ring gear tooth depth, as per the pics from this service manual below.
  #25 (permalink)
Old 07-17-2018, 12:20 PM
eschaider's Avatar
Patrickt is steering you in the right direction. I might consider having the material removed from the flywheel register that bolts to the crank. If you do it that way you kill two birds with one stone — you get proper starter pinion engagement with the flywheel and you also improve your TOB and clutch release arm clearance to the BH.
Ed
  #26 (permalink)
Old 07-17-2018, 03:31 PM
DanEC's Avatar
This is a mystery - seems to be a correct flywheel for your engine unless they got an incorrect one in the wrong box. But considering it bolts to the crank and takes a 12 inch Ford pressure plate the odds of that seem long. I have a Scat crank in my engine and an aluminum flywheel and I'm just sure it isn't sitting that far from the back of the block.
ERA 782 Running
  #27 (permalink)
Old 07-17-2018, 03:42 PM
I'd still like someone to explain why that flywheel specifically says it won't fit pre-1965 FEs. If SCAT mimics a pre-1965 configuration, then that flywheel won't work.
  #28 (permalink)
Old 07-17-2018, 04:07 PM
eschaider's Avatar
Is it possible that pre '65 FE's have a flywheel flange that is positioned differently on the crank or perhaps a different thickness — possibly both?
Ed
  #29 (permalink)
Old 07-17-2018, 04:12 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
Is it possible to exchange or return your flywheel? If not what about selling it?
Chris
  #30 (permalink)
Old 07-17-2018, 04:46 PM
AC Ventura's Avatar
I should say this is a Pond Block with an 1/8” block plate that came with the McLeod SSP clutch. My engine builder, an FE specialist, measured up another FE and told me the gap between back of flywheel and BP was not .55” like mine but similar at .48”. My flywheel M6375 N427 or that’s what is said on the box, is flat across the back, wheareas the one he measured had a .08” negative recess or step, which explains the difference. I can’t understand the variance between these flywheels, yet no declaration in in the spec.
As I said I now have 1/4” fresh air between the TOB and the clutch fingers, which seems okay, to me. I can mill 1/16” off the front of the PM Mini Starter and I’ll have full engagement. I prefer that to removing material from the flywheel and risking any run out, and potential failure.
If I was starting again, I’d ask SCAT to simply reduce the thickness of the crank flange by about 3/16”.
Also the McLeod plastic alignment thing did not align my clutch, despite two attempts. In the end used the TKO itself with the BH off.
I’m also considering taking out the 4” transmission crossmember and moving it back 2”, so I can get the trans in using the conventional mount, without tipping the motor. I intend to run an underfloor system.
  #31 (permalink)
Old 07-17-2018, 05:02 PM
AC Ventura's Avatar
A bit off topic, but has anybody made their trans crossmember removable?
  #32 (permalink)
Old 07-17-2018, 05:53 PM
This is the answer to that question: https://www.fordfe.com/viewtopic.php...965%22#p192349 It is not going to help fix AC Ventura's problem though.
  #33 (permalink)
Old 11-18-2018, 12:14 PM
hauss's Avatar
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Default Bellhousing
I’m wondering if this is the issue. Is everybody’ else’s flywheel so far from the block plate? The gap is 0.55”
I Think you were sent the wrong bell house. hold up the alignment tool when installing the clutch trany should slide right in with little effort
Display Modes
