Like Tree5Likes
  • 3 Post By Chilibit
  • 1 Post By CompClassics
  • 1 Post By Sledge
Old 09-23-2018, 03:39 PM
Cobra Make, Engine: SPF-427R
Default Avon CR6ZZ what tire pressures are you running
SPF with small block.
I was a little low on pressure and went up to 35psi all around and there was a significant increase in feel and turn. Wondering what is ideal.
Old 09-23-2018, 03:58 PM
18-20 unless I am on the track. I ran 26 at VIR. My tire wear is perfect. 35 is off my chart.
Old 09-23-2018, 05:26 PM
I was at 22. This way it drives much better
Old 09-23-2018, 07:29 PM
CompClassics's Avatar
The reason it feels better is because it is easier for the tire to roll and turn, grip is compromised though.
AC Ventura likes this.
Old 09-23-2018, 08:28 PM
gsharapa's Avatar
On my GT40 I run 26 in the front and 23 in the rear on my AVONs.
CAV GT40
Old 09-23-2018, 08:49 PM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 66+K miles and counting
For even tire wear on my BDR, I run 23 psi front, 16 psi rear. These numbers were obtained using an infrared temperature detector to obtain temp readings across the tread width, corrected for camber settings. As opposed to my usual method, which is pulling them directly outta my a$$.
spf645 likes this.
Bill
"If your work speaks for itself, don't interrupt"
Old 09-24-2018, 05:18 AM
Ron61's Avatar
I run 28 to 30 on all wheels on my Coupe. With my tires 28 seems to be the best as I get no extra wear and the tires don't overheat.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 09-24-2018, 10:41 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
My wife and I took out the CSX for a drive yesterday (she was driving). I had just put 26F/25R in our Avons and she noticed the car was better planted in the switchbacks.
rodneym
Old 09-24-2018, 12:20 PM
t walgamuth's Avatar
I have 24 in my Hoosier A7s. I have not tried them yet so will check back when I do.
Old 09-28-2018, 07:59 AM
i'm going to go down to 28 and see how it feels. thanks for the input.
Old 09-28-2018, 07:13 PM
Cobra Make, Engine: SPF #1019
19 rear / 21 front.
Old 09-28-2018, 07:31 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
24 psi front and rear. Had them at 32 psi once and it was way too firm. I have 245's on the front and 295's on the back and 22-24 seems about right with a good contact patch across the cross section
Old 09-29-2018, 01:08 PM
I'v been running 30F/28R, still have enough bit to brake an axle, when the car was delivered pressures were at 38F/38R, ride was junk. By the way still have 50% tread after 4k.
Mark.
Old 10-09-2018, 10:39 AM
cdog's Avatar
Avon CR6ZZ's: Currently running 25 lbs. all around, but I ran 18-20 lbs. for the previous few years. I really can't tell the difference.
Treadwear seems great on these, even with a few track days.
Old 10-11-2018, 07:10 PM
At the autocross last sunday I worked down to about 22 all around.
Old 10-16-2018, 06:21 AM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
Me too, but on a Mk IV. It's what the Autokraft Handbook recommends.
