Like Tree2Likes
Old 01-14-2019, 12:11 PM
Cobra Make, Engine: Arntz....Z28 302 chevy
Question newbe needs help.........
picked up an "older cobra" build...has a jag rear end...need to replace the four shocks......how do i identify which rear i have so i can search for correct replacements?... I beleive the car may be an older superformance...it is fiberglass.... any suggestions?
Old 01-14-2019, 01:01 PM
Post a picture of the car and of the rear end
Old 01-14-2019, 01:02 PM
LMH's Avatar
LMH LMH is offline
I don't think Superformance ever used Jaguar suspension. Does it have quad coil over shocks in the rear?
Alba gu brąth
Old 01-14-2019, 04:31 PM
Measure the distance between the inner pivot axis and the hub carrier axis. There are several length lower control arms.
Old 01-15-2019, 08:49 AM
yes it has quad coil overs.......old xke maybe?
Old 01-15-2019, 11:22 AM
All these had quad shocks:
XKE (early and late variations)
XJ Sedan
XJS (early)
MK 10 Sedan
Old 01-15-2019, 12:52 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
When you say "older build" cobra can you clarify "older"?
If it is indeed a Superformance you should have a chassis number stamped on the front cross-member and on a plate on the firewall or wheel housing. On paperwork maybe?
A very early Superformance has a different suspension then later versions. The wiring also differs....
Blas
SPFWiringDiagrams@Comcast.net
Old 01-15-2019, 01:35 PM
built mid to late 90's... shelby old factory in las vegas......has triump front suspension....jag rear end......was neglected in process of cleaning engine trany chassis suspension....all covered in old oil and dirt.....only id i could find was dmv id plate....last two digits were NV....plan on power washing this weekend so maybe i can find more info then....info i posted here was info i got when i bought it from widow.....so..
id post photos but havent figured out how yet....lol
Old 01-15-2019, 02:35 PM
That should narrow the make down - although I know of no kit that used Triumph myself. It's got a trunion on the bottom and ball joint on top?
Old 01-15-2019, 03:03 PM
xb-60's Avatar
..... shelby old factory in las vegas......
What information do you have that connects it to Shelby in Las Vegas?
Glen
Old 01-15-2019, 03:49 PM
LMH's Avatar
LMH LMH is offline
Not a Shelby if the front suspension is Triumph. They didn't/don't use Jag rear suspension either. Probably going to have to post some photo's, especially of the suspension and under hood frame. We could probably ID from there.
Alba gu brąth
Old 01-15-2019, 04:21 PM
joyridin''s Avatar
Sounds more like an Arntz. Jag rear, MGB front, Chevy engine, and it is an old build with no markings.
FWB likes this.
Old 01-15-2019, 04:31 PM
snapier's Avatar
Cobra Make, Engine: Superformance ford v8
An example of a Superformance chassis No#(SP01400).
Old 01-15-2019, 06:33 PM
LMH's Avatar
LMH LMH is offline
I was thinking the same thing.
Alba gu brąth
Old 01-16-2019, 07:25 AM
i think your on to something....i just looked at a video of an arntz for sale....had jag rear...underside chassis looks like mine.....dash layout is the same and so is center hump (very wide)....
Old 01-16-2019, 07:35 AM
actually it could possibly have been made in 1979....if anyone wants to message me i can then send the photos is took since i havent figured out how to post them here yet....
Old 01-16-2019, 08:49 AM
added some photos....
Old 01-16-2019, 10:22 AM
LMH's Avatar
LMH LMH is offline
With that giant fan shroud, Im more sure joyridin is right that it’s an Arntz.
Alba gu brąth
Old 01-16-2019, 12:24 PM
i never heard of that brand...are they ok?
Old 01-16-2019, 01:07 PM
cycleguy55's Avatar
There's an entire forum / area on CC for Arntz / Butler cars: Arntz/Butler Forum - Club Cobra
Brian
