Like Tree3Likes
  • 1 Post By tortuga
  • 2 Post By Ron61
Old 04-06-2019, 06:04 AM
Default When disassembling and reassembling an HP carb don’t do this
So I figured it was time to take the mixer apart, clean it and put it back together...which I did, I thought successfully...
A word of caution, these things are set up with no real front to back on the main body when looked at by the casual observer with one significant exception; everything is symmetrical except for the power valve ports between the throttle and main bodies, put the main body on backwards and they are blocked causing all sorts of weird tuning issues...
The main body on an hp outwardly has some female threaded holes on the secondary accel pump side, other than that they look pretty much the same but for asymmetrical power valve ports underneath that need to line up with the asymmetric ports on the throttle plate!
Sometimes you feel like a nut...and no that’s not a “good towel” I think...
Steve H
SPF 1764
ront49 likes this.
Superformance 1764
Built 427W
Aiken SC USA
Old 04-06-2019, 08:02 AM
Ron61's Avatar
Looking at that picture I can see where it would be easy to put it back wrong. I think I would take a permanent marker and make a mark on the front or back if I had to do it as I would for sure put it back together wrong otherwise.
jolsen42 and ront49 like this.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-06-2019, 09:50 AM
Default One of those silly things...
At some point back all the way out of all the steps and retrace them carefully...
Boy she runs night and day better with the carb on the right way!
Steve H
1764
Superformance 1764
Built 427W
Aiken SC USA
Old 04-07-2019, 06:27 AM
Jerry Clayton's Avatar
since you have oblong holes in the base plate--did you have carb mounted sideways on manifold?????
Old 04-07-2019, 03:30 PM
Default No
Had main body 180 degrees, an hp main body is absolutely symmetrical with the exception of power valve vacuum ports...
Superformance 1764
Built 427W
Aiken SC USA
