05-01-2019, 07:46 PM
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Jaguar Rear End Driveshaft Yoke
Looking for a XKE rear end driveshaft yoke and also a front yoke and spline for a Muncie 4 speed.
I need to build a driveshaft that goes from a Muncie 4 speed and will connect to a Jaguar XKE rear end flange.
At this point all I have is the Muncie front yoke and spline that Tom sent. I need everything else to mount Jag parts to the driveshaft to the rear end.
05-01-2019, 08:01 PM
WI
Cobra Make, Engine: ERA FIA kit on order
Just to be clear, you're not looking for the yoke for the pinion on the rear differential? I only ask because I recently rebuilt a rear diff with Dana 44 gears and I'm pretty sure I have the factory differential yoke sitting around somewhere. I'll take a look to see if I have the driveshaft yoke this weekend, but I'm nearly positive it got scrapped with the driveshaft so don't get your hopes up.
289 FIA ERA2159
Build in progress
05-01-2019, 09:02 PM
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
I have a front yoke and spline for a Muncie 4 speed. Send me your info and it's your's.
Tom
05-02-2019, 09:23 AM
Check with Terry's Jaguar...
Dan in Arizona
CCX3209
05-02-2019, 09:37 AM
Cobra Make, Engine: Unique 427 S/C - 482FE built by Survival Motorsports, 4 Spd. Toploader, Jag 3.31
Mid-South Gear in Knoxville, TN.
Talk to Butch Capps, he is a Cobra guy and rebuilds a lot of them.
Jeff
05-02-2019, 11:32 AM
Bearwolf, I'm looking for the yoke that bolts to the rear differential, maybe I'll get lucky and you'll still have it!
Tom, PM sent.
Thanks, Dan & Jeff --
05-03-2019, 11:24 AM
Junior Member
Jim, it's in the mail. Check your PM
Tom
05-03-2019, 04:27 PM
PM replied to.
Thanks !
05-03-2019, 05:21 PM
Call Jag Bits
05-04-2019, 06:23 PM
05-06-2019, 07:10 PM
NJ
Cobra Make, Engine: ERA 427, 482ci sideoiler
Jim,
I'm not sure what you are looking for with regard to the Jag rear differential. I have a Jag XJ6 rear differential assembly that had the driveshaft cut off about three inches from the rear universal joint. If you are looking for "the rear driveshaft universal joint and flange" which bolts to the flange bolted to the differential pinion shaft, I have one. Let me know if that is what you are looking for.
05-06-2019, 07:12 PM
NJ
Jim,
05-06-2019, 07:35 PM
PM sent
05-07-2019, 07:41 PM
WI
Well the bad news is I cant seem to find it. I must have just thrown the whole drove shaft in the scrap bin knowing I'd never use it. If I run across it it's yours, but even though I dont remember scrapping it, that's probably what happened. Sorry
289 FIA ERA2159
Build in progress
05-07-2019, 08:07 PM
No problem, Bearwolf --
Thanks for looking for it.
05-18-2019, 06:50 PM
Thanks to John ERA174 and Tom Howland I now have the parts needed to have the driveshaft built.
