November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree2Likes
  • 1 Post By saki302
  • 1 Post By saki302
Old 08-09-2019, 05:10 AM
saki302's Avatar
Cobra Make, Engine: Superformance Mk3, Roush 427
Default TKO600 / 351W block clutch slave cylinder
Hello,
I just buttoned up my transmission tonight on the superformance, everything seems to work- we’ll start it up tomorrow and check it on the jack stands.
I noticed my clutch slave cylinder push rod sits at an angle, down and inwards a bit. I think this is what caused the premature wear on the old clutch fork by pushing on it downwards.
Is there a recommended replacement? (TKO 600 trans, aluminum bellhousing, 351W block)
I found this online and it looks like it would work:
Rosehill Performance Parts 3550, TKO 500/600 Bracket Kits:-
Here is what mine looks like now: (I tried both mounting holes down low- it's on the better one already)
Thanks!
-Dave 2028
Old 08-09-2019, 08:35 AM
twobjshelbys's Avatar
Mike Forte's kit.
Tony
CSX4005LA
Old 08-09-2019, 10:43 AM
SLP SLP is offline
Cobra Make, Engine: A&C, 351W .040” over, TKO600
I took all that hydraulic to mechanical stuff out of mine and went with a hydraulic throw out bearing with one piston at the pedal and it works amazing. It wasn’t expensive and it was easy to do.
Old 08-09-2019, 11:58 AM
There is much discussion about the HTOB (Hydraulic Throw Out Bearing) vs the classic master/slave configuration somewhere here. I don't have time to look for it now since I'm on my way to an appointment. The bottom line is that the misalignment you mention is even more deadly (and more probable) with the HTOB. I went through two before I switched to Forte's config and never had another problem. Maybe someone else can remember where the other topic is.
Tony
CSX4005LA
Old 08-09-2019, 02:29 PM
saki302's Avatar
I just ordered one from Forte. Mike still had my information back from 2011.
I figured get the good one, do it right and never worry about it again ��
-Dave
Old 08-09-2019, 07:07 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
I don't think a new cylinder will fix it. The block surface isn't flat. You need to put a shim under the low spot and it will pull it into the correct orientation.
John
Old 08-10-2019, 11:30 PM
saki302's Avatar
It's not the surface. The bracket offset puts the cylinder too high and out, so the rod sits at an angle. Photo is an odd angle.
-Dave
Old 08-11-2019, 05:25 AM
Cobra Make, Engine: BDR Build #1054 351W stroked to 427
Changed my slave cylinder to a HTOB and it works great. Got rid of the slop and constant readjustment and as far as I'm concerned it's the best thing I ever did..
Old 08-12-2019, 10:24 PM
saki302's Avatar
Forte slave is in!
Very nice looking part and slick setup. Many adjustments to get the angles just right.
Of course now my hydraulic line is too short Ordered parts from summit (Earl's) to build a new one.
-Dave
spdbrake likes this.
Old 08-12-2019, 11:01 PM
Gaz64's Avatar
Originally Posted by saki302 View Post
Forte slave is in!
-Dave
Very nice setup you have there Dave.
Less hassle if you ever have a failure, unlike HTOBs IMO.
Gary
Old 08-13-2019, 12:05 AM
saki302's Avatar
From what I've read, I decided to avoid the hydraulic TB.
My old setup worked, it was just a little mickey mouse..
-Dave
Gaz64 likes this.
