Like Tree4Likes
Old 05-26-2020, 09:37 AM
hauss's Avatar
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Default Tires
I am running nitto nt 05s on my car and thinking of changing to a different tire. I do not like the way the front tires, cause the car to jump around.What would be a good performance tire with good manners that you could recommend ? 245 17 front and 315 17 rear car is a 2013 backdraft around 600 hp. Thank you for your thoughts.
Old 05-26-2020, 10:53 AM
bobcowan's Avatar
I have the same tire, and don't have that problem. Maybe your alignment is off? Something loose? Corner weights off? How old is the tire?
I recently replaced my rear tires. Apparently, the NT05 is in limited supply, and no new product expected. It may be discontinued soon?
Do a little search here. You'll find this question has been asked many many times. You'll get a lot of good answers and good suggestions in <1 minute.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 05-26-2020, 11:40 AM
hauss's Avatar
Could be from sitting, I have looked on site but reely could not find anything useful.
Old 05-26-2020, 12:27 PM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Just about any high performance tire will cause your car to dart on a rutted road. Does the same on my 2011 GT Mustang when I went with a higher performance design.
I'm running Mickey Thompson Street Comp Ultra High Performance Tires and love them.
But they too, dart on a rutted asphalt road, not so much on concrete.
hauss likes this.
Old 05-26-2020, 12:51 PM
Tom Wells's Avatar
hauss,
Manners? High performance? Maybe that's a "just pick one?"
As to jumping around, there are a number of other things other than tires that can make that worse:
Alignment: toe-in, caster, camber
Condition and adjustment of the front shocks,
Play in any of the front suspension components or steering (remember if they are there - the u-joints in the steering shaft - those were only slightly loose on mine but had a big effect).
Hope this helps,
Tom
Old 05-26-2020, 12:59 PM
Cobra Make, Engine: SPF GT40
Nitto NT-01. They're a track tire, not a drag tire like NT-05. Would I drive either one in the rain? No.
Old 05-26-2020, 03:02 PM
Tom Wells's Avatar
Swift,
Don't do like I did and get the tire labels confused: the NT-05 is a wear rating 200 street tire. If you want to go drag racing, add R so you get NT-05R.
The NT-05 is OK in the rain. Not outstanding, but adequate. The NT-05R would be dicey...
Nitto says the "R" designation has a wear rating of 00 LOL
The NT-01s are intended for road racing and have a wear rating of 100.
Tom
Old 05-27-2020, 08:10 AM
hauss's Avatar
Thanks Infletcher I will give the mickeys a try. Wounder if I should change the fronts from 245 to 235 . let me know what you guys think, I am no expert in this area and need a lot of help.
Old 05-27-2020, 11:52 AM
lnfletcher's Avatar
I don't think 10mm will make a difference on the feel.
Old 05-27-2020, 02:04 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
The jumping around is tramlining. It occurs more frequently with wider tires and more aggressive alignments. You could put more caster in the alignment to reduce.
NT01s are what I run, but they are no good wet. I have no intention of driving in the rain. FFR recommends Toyo Proxies R888. They have a good rain rating, but I have never tried them. They are available in the sizes you are looking for. Toyo and Nitto are sister companies, from what I've been told.
Good luck, be safe
Mark
PS: Try 22 psi to start with that size tire on the Cobra.
Old 05-27-2020, 02:10 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I am running the the PS2 335/35 17" on my SPF. Good tires
https://www.amazon.com/photos/shared...1ibQ-R-zmbovc8
Old 05-27-2020, 10:31 PM
hauss's Avatar
Very nice car! very expensive tires twice as much as the mts.
Old 05-28-2020, 08:29 AM
scootter's Avatar
There's a lot riding on my tires. Michelin
Old 05-28-2020, 06:43 PM
hauss's Avatar
Guess what ,you are not going to believe this. I lifted the car and started checking things and found that nt05s are directional . looks like when the fronts were installed, they got them wrong. Must have been looking at the car from the front,instead of the divers seat.
Old 05-28-2020, 07:01 PM
Just switch passenger side to driver side and *poof* they'll be in the right direction. Just like magic.
Old 05-28-2020, 07:25 PM
bobcowan's Avatar
That only matters when it's wet. It's due to the water grooves in the tread design. On dry pavement, it won't matter at all.
.boB "Iron Man"
Old 05-28-2020, 11:03 PM
hauss's Avatar
I hope you are wrong car seems to be nervous I hope this will settle it down some. Tire size on front is 255 45 17 maybe to wide wants to grab everything like a high school kid in a whore house.
Buzz likes this.
Old 05-28-2020, 11:07 PM
hauss's Avatar
Thanks, but I was hoping for a more detailed you should buy this tire and this size because it will do this for you answer
Old 05-29-2020, 07:43 AM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Do yourself a favor, make sure your toe-in is correct before you buy new tires. 1/16" to 1/8" toe-in, favoring the 1/8" to see if it makes a difference. Toe-out with tires like yours will dart all over.
hauss likes this.
Old 05-29-2020, 11:08 AM
hauss's Avatar
To whom it may concern . I switched the tires today and went for a drive. All I can tell you is night and day difference ! Nittos are directional and yes ,they are very sensitive, if installed backwards, on a cobra. Also dropped the tire pressure to 22 psi, as recommended on a different post ,with these tires and our cars.
