February 2026
Like Tree1Likes
  • 1 Post By my427cobra
Old 06-28-2020, 03:12 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default Rear sway bar links
As I'm fabbing my scratch build independent rear suspension, I am at the point of figuring out my rear sway bar.
I am planning to use a 1999/2000 Miata rear sway bar 22mm in diameter. That diameter should be sufficient for street use.
It is very close to the width dimensions I need and readily available.
I would appreciate any wisdom/advice as to the angularity of the links.
Here are a few pics of what I've dummied up.
I would imagine the the links would be best if they were near vertical at static suspension position ( lower a-arm not in motion and not in compression or droop).
Looking forward to your input
