93Likes
08-29-2021, 02:08 PM
Cobra Make, Engine: era#671 Keith Craft Motor
Haa! I remember back then meeting Walt Senior and the son...I think Junior was spraying back then but i could be wrong.I think my car was done around 2005 and has held up well...If i was to do it again i would eliminate the Heating system being i never have used it and maybe would of considered a Borla EFI webber look instead of Carb...
08-29-2021, 04:57 PM
CO
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
All things considered, pretty much everything you can see without going under the car looks the same on a ERA and SPF. I would take the much stiffer ERA frame and much better suspension every time, a far superior driving experience. Just my opinion.
08-29-2021, 06:36 PM
Uhhh, windshield wipers parking on the wrong side, radiator slant looks funky, pedals aren't coming up from the floor and more.... But you didn't hear that from me.
08-29-2021, 09:02 PM
Cobra Make, Engine: Alloy Shelby CSX 8057/Kirkham 1010, 289 Vintage Lykins Build
Can you clarify your comment on the pedals? Looks to me that both the SPF and ERA slabsides have the clutch and brake hinged from the floor. Not sure about the gas pedal. Just looking at pictures.
08-30-2021, 03:46 AM
Both the SPF and ERA 298 cars have the clutch and brake hinged at the floor. I cannot speak for the ERA 289 from first hand knowledge, but the SPF 289's have the Gas pedal hinged at the top like the originals.
People sometimes get mixed up between the SPF cars and think that they are all alike frame and suspension wise like the ERA cars. The 427 cars are similar to the ERA with a box frame and the 289 cars have the 3" tubular frame.
What ever decision you make, will be the right one for you. Both are very good cars. Good luck.
08-30-2021, 04:45 AM
No, I was speaking generically about 427 cars.
08-30-2021, 09:58 AM
NV
I still don't understand how a topic that is titled "Kirkham vs Shelby" transformed in to SPF vs ERA
CSX4005LA
08-30-2021, 10:18 AM
Abnormal CC Member
Originally Posted by twobjshelbys
I still don't understand how a topic that is titled "Kirkham vs Shelby" transformed I to SPF vs ERA
It seems Kirkham was much much more expensive than originally thought. He wants a 289 slabside. The SPF slabside is extremely similiar (if not identical) to the Shelby version, so why not consider it. Even in the first post he mentioned considering the ERA slabside. So this seems like a perfectly normal progression to me.
08-30-2021, 10:24 AM
Cobra Make, Engine: SPF832, 466cid
What's your point? The OP opened up this thread about a small block genre.
08-30-2021, 10:30 AM
Yes, but my reply was to 6TNCRZY's post which was commenting on ERA's and SPF's similarity generally and not distinguishing between big block or small block.
08-30-2021, 11:08 AM
Well the OP needed clarification of your off track comments. Did you help his cause or your posting count?
08-30-2021, 11:12 AM
How could I do one without doing the other?
08-30-2021, 11:18 AM
Yes, this topic has evolved from the title. Apologies. But, it was a progression as more information unfolded. Especially the unexpected high cost of the Kirkham (~$250K).
The continuing interest is in a small block Cobra. Primarily a Slabside or perhaps an FIA.
I suppose I can stop writing to this thread because of the now potentially misleading title and create something new as needed.
08-30-2021, 11:21 AM
That, or just announce that you've decided on an ERA. The latter will provide additional fodder for irritating NROTOXIN.
08-30-2021, 11:30 AM
NV
The down side of shifting the discussion is that it had just as well been posted in Alpha Centauri. (Only old people will get the reference.)
Some searches may discover it, but there is lots of good information on both paths here, but only the Kirkham/Shelby info will bubble to the top in a year or two. So then we can come back and have a brand new topic about the merits of SPF vs ERA. But that's OK, this forum thrives on lather, rinse, repeat.
CSX4005LA
08-30-2021, 12:45 PM
SK
It's unfortunate that threads can't be re-titled. Perhaps "Small Block Cobra Comparison / Recommendations"
Brian
08-30-2021, 12:49 PM
... or instead, "Why I'm Right and the Rest of the World is Wrong."
08-30-2021, 01:05 PM
NV
But then that would be the title of every topic.
CSX4005LA
09-01-2021, 05:33 AM
While researching the small block ERA cars, and backdating one to 260 specs, I stumbled on a English company Hawk Cars. They make kits of the small block Cobras, plus the 2.6 Ace, which is the car that became the Cobra , plus the Barchetta 166M Ferrari Mustache AC Ace cars. Like the ERA, they all have coil over suspension. I then discovered a sight where an enthusiast is building an Ace, and going over board trying to make it perfect. Below is an article on adding dummy leaf springs, which might also be used on the ERA, so when you pop the bonnet, you will see the correct springs! Oh, and don't forget to wrap your leaf springs with Drevo tape, like the original cars. https://aceac.weebly.com/dummy-leaf-spring.html https://www.vintagecarparts.co.uk/pr...evo-denso-tape
09-01-2021, 11:57 AM
it is not,
Kirkham vs Shelby is about original specs of chassis and body and about the question if the csx tag and the fact that the car turns into a genuine “ Shelby Cobra” is worth some ten thousand bucks
SPF vs ERA is about which lookalike is better
complete other discussion
