Old 08-08-2021, 02:02 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default Does bellhousing hang below round tube frame?
F5 mark 4 cobra, does the bellhousing sit above or below the 4" round frame, trying to figure out ground clearance.
thanks,
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 08-08-2021, 02:18 PM
t walgamuth's Avatar
Although lots run with their oil pans down below the frame I would not. I'd get the most compact pan available and go from there.
Old 08-08-2021, 08:54 PM
Dwight's Avatar
Smile
I ran a road racing pan. Stock height with 8 qts capacity.
Old 08-09-2021, 03:28 AM
1795's Avatar
He's asking about the bell housing on an FFR. I can't answer that question for you, as I have an SPF and mine is the 289 model with the 3" tubes.
Old 08-09-2021, 06:53 AM
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
Generally, yes. Many builders on the FFR forums mention this. Seems to hold with 302/351 and Coyotes. The recommendation is often to cut the bottom of the bellhousing to match the bottom of the 4" frame rails. There are also many warnings about having an oil pan sit below the frame rails.
Having had two SPF cars I was accustomed to the front sway bar being the low point under the frame at the front and used that as a guide for what hung down. In 65,000 miles never hit the bellhousing or oil pan. This was with a 3-1/2" or so height to both and driving cross country, city, country and dirt roads. YMMV
The standard recommendation for chassis height on the FFR at the bottom of the 4" frame tubes is 4" at the front and 4-1/2" in the rear. This is an approximate and often varied from. The SPF chassis used similar heights.
I understand the concern but wonder if this merits the effort.
Jim
Old 08-09-2021, 07:00 AM
Cobra Make, Engine: B&B-McGill
Found this photo. Not sure if it will help.
Old 08-09-2021, 08:15 AM
Exclamation need a stock bellhousing measurement
I need a stock 302/ T5 bellhousing measurement- above or below frame- for F5 mark 4 as a reference point for my AOD and it's trans pan height. On my 1st shell valley cobra my C6 pan was low and banged speed bumps
Old 08-09-2021, 01:06 PM
Neutral
3/8" below the frame rail.
https://thefactoryfiveforum.com/show...4-Bell-housing
Old 08-10-2021, 03:19 AM
Jim
Cutting off the bell housing will leave the flywheel exposed, won't it?
Old 08-10-2021, 05:21 AM
If you follow the FF forum link that was provided by spdbrake apparently one guy did it with success.
Old 08-10-2021, 05:56 AM
You only cut part of the lower flange. Maybe 3/8-3/4".
No, you don't cut into the flywheel area.
Jim
Old 08-10-2021, 08:55 PM
I see. That is a lot less than I imagined. Of course that lip around the bell housing flange is like the web on a steel beam so any cutting on it will weaken it some.
Old 08-11-2021, 07:16 AM
DanEC's Avatar
Not all aftermarket bell housings are the same. In general QuickTime are a bit more compact than Lakewood. Also QuickTime makes a non-SFI rated, steel bellhousing with a block saver plate that is quite a bit less bulky, especially along the bottom part where it does away with the heavy, wide flange and continuous row of large bolts - for a narrower flange with just a few small machine screws. If you going to the strip or someplace you need an SFI rated bellhousing this is the way to go with a Cobra. Good ground clearance, heavy steel bell with the weakened zone oriented down, block saver plate, usually dials in good on factory dowels.
ERA 782 Running
Display Modes
