Like Tree1Likes
  • 1 Post By KarlzEE Bebout
Old 07-22-2023, 07:04 PM
Default Protecting the wheel from safety wire
What is used to protect the finished of the wheel from safety wire the spinner?
Old 07-22-2023, 07:15 PM
twobjshelbys's Avatar
I used insulation I stripped from 20 or 22 gauge stranded wire.
My wheels were painted so I used the yellow.
Ps. Had my wheels not been painted I wouldn't have bothered.
Tony
CSX4005LA
Old 07-22-2023, 07:23 PM
I use neoprene (or any rubber) hose. About 1/8" I.D.
Found clear hose on Amazon
joyridin' likes this.
Old 07-22-2023, 07:28 PM
FredG's Avatar
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Originally, my car came with clear rubber hose. Take a look at this link and you will be able to find something a little fancier. I used blue and white to match the car. I also used larger sizes to cover my engine hoses. Gives the engine compartment a nice finished look.
https://www.cabletiesandmore.com/gen...aided-sleeving
Fred
Old 07-22-2023, 07:30 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Hospital IV Tubing
SPFWiringDiagrams@Comcast.net
Old 07-22-2023, 07:34 PM
FredG's Avatar
Default Wire covering
Fred
Old 07-22-2023, 09:19 PM
Cobra Make, Engine: SPF832, 466cid
Nothing......free balling.
Old 07-23-2023, 01:46 AM
Cobra Make, Engine: Shamrock
Clear 4mm plastic tubing in the area of the spoke. Dirt cheap and clear so not really noticeable. Bought a meter and cut roughly 150mm lengths.
Old 07-23-2023, 05:00 PM
Thank you for sharing
Old 07-24-2023, 05:04 AM
Sawdust's Avatar
Any clear plastic tubing 1/8” diameter. Cut it to length
Old 07-24-2023, 07:53 AM
1985 CCX's Avatar
Just put on loose, it is meant to be a check and not actually a back up plan for tightening correctly.
Old 08-02-2023, 05:14 AM
Same here, except I used black on standard Trigo wheels.
Crendon 427, in the making
http://crendonreplicas.com/
Old 08-02-2023, 11:55 AM
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I don't suggest that anyone follow my former plan.
I tried many of the solutions listed. Finally gave up and followed a racers solution. Which didn't include the safety wires.
I'd install the spinners and hand tighten while off the ground. Don't smack 'em in the air, just not enough resistance to lock up. Then I'd lower until the tires were touching the ground and tap the spinners. Once fully supported I'd hit 'em again. After a short drive I'd hit 'em again.
Never had an issue. Two SPF cars and about 50k miles this way.
Jim
Old 08-03-2023, 10:40 AM
xlr8or's Avatar
Just put some heat shrink on that section of the wire.
