Like Tree1Likes
  • 1 Post By Jim Vander Wal
Old 04-25-2024, 04:16 PM
Default Replacement for 305 rear tires
Just got my Superformance SC and need new tires. What are folks using these days.
Regards,
Jerry
Old 04-25-2024, 10:38 PM
Cobra Make, Engine: Superformance MKIII Ford Big Block
What size wheels are you running? (15, 17, 0r 18)?
Old 04-26-2024, 04:04 PM
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I ran Michelin PS2 335/35-17 and liked 'em. These are still available, 3 others that I ran no longer are.
There are many 315s in 17" and a few 335s. 305 isn't as common.
It's generally best to run similar (not size) tires front and rear. If the rears are worn out the fronts are probably aged out.
Jim
former owner of SPO 1855 and 2584
hauss likes this.
Old 04-27-2024, 01:41 AM
I am running 15" wheels. Should have mentioned that in the original post.
However, as a follow-up: is it difficult to find tire dealers that can balance the pin drive wheels??
Regards,
Jerry
Old 04-27-2024, 05:50 AM
Pin / Lug bolts No difference in balancing or mounting.
Jim
Old 04-27-2024, 08:27 AM
Cobra Make, Engine: SPF GT40
295 is probbably as big as you're going to get in a 15" size.
Balancing pin drive wheels is no problem. Have had many done at big tire chains.
Old 04-27-2024, 08:47 AM
65snake's Avatar
Cobra Make, Engine: ERA#407, 428FE SOLD ERA #3032 331/DART
On ERA407 I had Bill Boards "Goodyear Vintage Sportscar Eagle Cobra Tires" (26.5 x 8.0-15) front part #478-2546 at JEGS and (26.5 x 10-15) rear part #478-2547. Great for shows and short local trips. But these are not suited to long trips and they do hunt and follow seams. I started taking much longer trips with the local Cape Coral Cobra Club (2 to 3 hundred miles) and changed over to Goodyear Eagle GT ii Radial TA 295/50R15 rear and 245/60R15 front. Don't think you can get these anymore unless from vintage tire dealer (read EXPENSIVE). Probably would go to BFGoodrich for long road trips.
Old 04-27-2024, 09:57 AM
twobjshelbys's Avatar
Assuming some readers are not tire savvy...
Billboards are NOT DOT approved for road use. They are bias ply tires. As such they are more susceptible to sidewall damage. The risk is that if you are in a wreck and your tire blew out it's a target for a law suit since your tires are technically not street legal.
On the other hand, remember that Ken Miles ran those same tires on the Mulsanne Straight at almost 200mph...
I was offered for a ridiculously low price a set of billboards and asked the guy why he was changing and he said "worst tire I ever drove"...
Tony
CSX4005LA
Old 04-29-2024, 02:20 PM
cycleguy55's Avatar
Regards,
Jerry
I the Nitto NT555RII is available in 325/50R15, but I have no idea what tire you'd run on the front. I'll also note they're 27.8" in diameter.
Brian
