| 29 |
03-05-2003, 07:58 PM
Jaguar or...........Dump truck
I noticed from the begining that my Contemporary was not the tight turner I expected from a car with these dimensions.
However , I m just completing my new garage in a portion of my old driveway, and have created a new "t" turnaround.
I've been using it for a couple months during construction ,but hadn't had the Cobra up and running for a few months, until this last weekend..............................
That jag front end is worse than my E250 !!!
Is this typical for Cobra ....or just Jag..........or just MY Cobra......and can it be adjusted......
thanks.......big rig Karl
03-05-2003, 09:03 PM
OR
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Karl,
My Contemporary had the same issue yours has, but I never expected it to turn around in it's own length. I don't think there's much you can do except to have a front end shop look at it to see if the steering rack is traveling it's full length both ways and that there is no bind up.
Anywhere but in a confined driveway, I found mine to handle the twisties very nicely and was very nimble in traffic.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
03-06-2003, 06:15 AM
IN
Cobra Make, Engine: Contemporary-Aluminum 484 FE
You have to determine which rack you have. You probably have an aftermarket Jag rack. If you want quicker steering you need the XKE rack. Call Terry's Jaguar in Benton , Illinois , and explain what you want or have one built. I have a quick rack I bought from Terry's, and it works fine. You might also speak with George Petrus at Accurate Machine.
wt
03-06-2003, 06:20 AM
UK
Cobra Make, Engine: Dax Tojeiro, 450bhp 383 ci Stroker, Tremec TKO and Contemporary CCX, Big Block Ford, old school.
Surely a quick rack won't improve the turning circle at all, but it will make the steering heavier.
My Kit uses Jag suspension and steering, and I agree that the steering lock is pretty poor. But with 9" wide wheels at the front and low suspension there isn't much room for a wheel to turn under the arch.
Kev Davies, Wales (UK)
CCX-3-4028.445 ci Ford FE
03-06-2003, 08:38 AM
Thanks for the replies guys, I actually have the "e" type steering and I like the handling just fine, its the huge turning radius that stunned me. but you are probably right ,with the big tires and low body I maybe couldnt use it any way.
I wonder about other manufacturers?
03-06-2003, 08:43 AM
Cobra Make, Engine: SPF - 427 Stroker
Turn wheel opposite lock - depress clutch, put'er in 1st - raise revs to 4000 - dump clutch. Works for me
NEVER LIFT
03-06-2003, 08:46 AM
LOL
03-06-2003, 09:32 AM
kk my midstates mustang 11 front end same deal my volvo turns twice as fast as the cobra, nature of the beast i guess. ron
cobrakit66
03-06-2003, 06:17 PM
The Arntz uses an MGB front suspension. I have often thought of upgrading it to somthing more modern. It does have a nice feel and a very tight turning radius, though. After reading your post, maybe I better leave it alone.
Paul
03-06-2003, 07:15 PM
OR
Karl,
I should have noted that I did NOT have a Jag rack in my Contemporary. Mine was MG as were the original Cobras.
That brings up an interesting question for owners of original 427 cars to answer.....how they feel about their turning radius? I never thought to ask the owner of an original, or even pay much attention as I watched them turn around.
Al
--Carroll Shelby
03-06-2003, 10:04 PM
I like Agro's answer. Reducing Turning radius requires two inputs; The steering wheel and the gas pedal.
