| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
07-04-2003, 07:26 PM
Unless you'[ve got a high reving race engine, you're actually better off to use *lower* octane gas. Low compression engines can get more energy out.
07-05-2003, 02:02 AM
nsw
Cobra Make, Engine: .
for what its worth, i use toluene with 98octane fuel at a ratio of about 10% in my 347 with alloy heads and 10.18.1comp
it dosent really increase performance by the seat of you pants but
the throttle response and overall smoothness of the engine is very noticeable
07-05-2003, 08:47 AM
Charter Club Cobra Member
OR
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
Home Brew Octane Booster
This has worked well for me,
Scott S
Working as hard as I can every day to double my carbon footprint.
07-05-2003, 10:38 AM
AR
Cobra Make, Engine: FFR 4859GT Spyder GT 414W EFI
Howdy,
toluene is real safe to use. I know people who use it in their meth labs and they have only burned their trailers down a couple of times ( I'm being serious about this part). Just try not to get any on your paint job!
"A veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of 'up to and including my life.'" (Author unknown)
07-05-2003, 11:13 AM
Tx
Cobra Make, Engine: CSX 4039 427 FE 1966- SOLD
Okay, so what should I use?
I have a 1966 427 FE with dual carb setup 10.5:1 compression, medium riser.
I think I run okay on Chevron 93, but sometimes it burps alittle bit at start up, more if not really warmed up.
Should I use that lead substitute since I have honest pre- unleaded gas engine? What additives if any?
thanks,
Brett Bolte
My carbon footprint is bigger than your carbon footprint.
07-05-2003, 11:55 AM
Bret,
If you are still using the original valves, I would say yes. If they have been changed to newer ones, then the lead should not be needed.
The lead ( anti-knock coumpound) served two functions in gasoline. One was to increase octane and the other was to lubricate the valves. I heard that when unleaded gas first started being used (1975) the car companies added valve rotaters to solve this problem.
I was told that it was 10 times more flamable than gas. I know that it certain building we even had to use brass tools to avoid any chance of causing a spark.
Bud
07-07-2003, 07:42 AM
MA
Cobra Make, Engine: Superformance#1325, Miller Machine FE
captain
The deal is not done until tha car is in the driveway but the two under consideration both have 351 Strokers net 408cubic in, 10.50 compression ratio making around 500 Hp.
Everything has a downside, so dwell on the positives. Find humor in the tough times.
07-07-2003, 12:24 PM
Cal
The way it was explained to me is that a long duration cam will bleed off cylinder pressure at lower rpm's, but at the working rpm of the motor, you still need the fuel to have the octane rating that the static compression dictates. So if your cam (and rest of motor) is made to run 8000 rpm, you can put around town on lower octane gas, but if you are going to run it to 8000, you need the proper octane rating. What I have seen is when a high compression motor is putt-putted around on too low octane fuel, it just fouls up the plugs, but when put to hard work on the same fuel, it cracks spark plug insulators. You all do what you want with toluene and your $10,000 motors, I would rather buy sunoco 114 and mix that with 92.
07-07-2003, 03:59 PM
Nantucket,
Sounds radical. What brand Cobra?
-The Captain
07-08-2003, 05:14 AM
MA
cap
Superformance
07-08-2003, 06:55 PM
wise choice. There are some good buys around used.
-The Captain
07-09-2003, 05:16 AM
MA
captain
Have you ever looked at Factory Five ? They are right here in Mass. within an hours drive.
07-10-2003, 08:11 PM
CT
AMSOIL
RE: AMSOIL
2206 Winter St
Superior WI 54880
Series 2000 Octane Boost
Sent the following e-mail on July 6th, did not receive a reply, your thoughts ?
Date: Sun Jul 6, 2003 6:17:16 PM America/New_York
To: tom@bestoil.com
Subject: Octane Booster
Tom:
Page 19 from the Factory Direct Catalog:
The Series 2000 Octane Booster mentions a 4 to 5 point octane increase from 88 octane fuel. To clarify:
* Octane increases from 88.0 to 88.4 or 88.5, or
* Octane increases from 88.0 to 92.0 or 93.0
Which of the above is correct ?
07-11-2003, 01:17 AM
Ga.
Unless there is a revolutionary new product on the market, It would take far more than a few ounces to bump 88.0 to 93.0......
Perry
07-11-2003, 02:58 PM
Nantucket,
FF5 compared to Superformance is comparing an Emersom TV to a Sony. Nuf said.
-The Captain
07-11-2003, 08:25 PM
NV
Cobra Make, Engine: Levy Racing built FFR w/351W
Originally posted by captain FF5 compared to Superformance is comparing an Emersom TV to a Sony. Nuf said.
While it is true that FFRs vary quite a bit due to the fact they can be built to any price point or skill level, your comment is ridiculous and a slap in the face to those that have taken their builds to higher levels.
Any of the professional builders in the country could build just as good or better rollers than Superformance, starting with the FFR kit, if that is the direction someone wishes to take. At equal or better pricing.
Most FFR owners build their own and take pride in their build as no one on the African assembly line can.
07-12-2003, 05:54 AM
Toulene
I've been using Toulene (or Zylene) in both my Grand National Buick (Turbo) and my Buick powered Cobra (11.5:1) compression for several years. Simply mix either at 10-20% (no higher) with a good grade of 93 octane and you get a true 96-98 octane fuel. Its cheap and easy to use. I ALWAYS mix it in a can first though.
Also, commercial octane boosters are a joke. If you could put 12 ounces of ANY chemical in a full tank of gas and get 100 octane the oil companies would be doing it.
The other alternative is mixing race fuel with 93 octane to get what octane you need. Turbo's need a lot of octane depending on the boost. My Cobra only needs a little over 93 to be "happy".
Bob
Johnex Cobra, Buick V6
07-12-2003, 05:43 PM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Hey Guys:
Just a couple of thoughts -
Octane booster is as effective boosting octane as those bracelets are at getting rid of aches and pains.
There are some beautiful FFR cars out there, I saw one tonight.
Bob
07-12-2003, 09:20 PM
Bart,
I think you are letting your emotions run away with your common sense. The FF5 chassis doesn't compare to the Superformance. If the exceptional builder throws away the FF5 chassis then all he has left is the donor car and the bill of sale. Just ask Outlaw [a FF5 dealer] how he modified his FF5 to make it safer and better. Also his asking price of $60,000.
-The Captain
07-13-2003, 09:20 AM
FL
Cobra Make, Engine: Hunter 427, 5.0 (302)
Captain
It is not polite to knock others cars just because you could afford a more expensive car. Kind of like a Porsche Turbo driver saying his car is better than your Cobra right before you spank him in a drag race.
I have a Hunter Cobra and to me the chassis is as good as a Superformance as they are both ladder frames and both use a IRS suspension. (Ford on SPF and Vette on Hunter) If you build a FFR with a IRS suspension it is comparable to a SPF suspension and the car is a little lighter to boot. The SPF has a little better body because it has a liner on the hood and trunk but it is made from fiberglass just like all other kits out there.
I would guess if SPF sold kits they would look about the same as almost all kit Cobras look like before they are assembled.
Don't get me wrong I think the SPF cobra is a great car and one of the best body shapes with a very nice interior. The frame is nothing special except they use a IRS type suspension that is made from all new parts. If you built a FFR that way it would have a similar cost and the quality would be similar.
I have seen many FFR cars on road courses and they usually run up front in the Cobra crowd.
| Thread Tools |
| Display Modes |
Linear Mode
