Old 08-03-2003, 01:04 PM
ENTDOC's Avatar
Default reverse rotation 427
Is it the cam that has to be changed in a marine motor to establish proper rotation? chuck
Old 08-03-2003, 01:19 PM
David Kirkham's Avatar
Original Shelby Owner
Smile
I have heard the crank is going the wrong direction as well. (The little oiling grooves on the back of the crank will pump oil OUT of a normal motor.)
Also, BEWARE of salt water corrosion. They use fresh water for cooling, but a marine environment is tough on things.
That said, I have seen many, many of them bring good service to their owners.
Old 08-03-2003, 01:37 PM
Will a reverse rotation motor haul ass backward in 1 st gear?
Ernie
Old 08-04-2003, 10:34 AM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
I think your right about the crank,it is different.the marine blocks are the best 427 {fordmfg}blocks out there,they have very high nickle steel like the c5 and c6 blocks,contrary to the adds I see on ebay,the c8az G service block is just iron like a 390 ,not as strong as a marine,the marine block also has .125 thick cylinderwalls,compared to .080 in most others.it will satand up to more bore,and much higher compression.Tk
Tk
"this whole Adult thing just isnt working for me "
Old 08-04-2003, 11:44 AM
427 S/O's Avatar
You can have a machine shop reverse the knurling on the crank for the oil seal, not expensive.
Perry
