Old 11-14-2003, 04:58 PM
tritoncobra's Avatar
Default Rate my new dyno sheet!
This is a 351W (not stroked) built by Eric at Performance Engineering in Ross, Ohio (http://www.perfeng.cc). .544 lift cam, runs on pump gas (93 preferably).
The results? 485 HP, 445 lb-ft! Is that insane for a non-stroked 351W or what??
Old 11-14-2003, 05:03 PM
Cobra Make, Engine: NAF replica, 351W, about 420 HP
I'm Jealous!!! Hope you have a lot of fun with that mill!!
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
Old 11-14-2003, 08:53 PM
Thanks Edley, let's just see how much of that power I can actually put to the ground..
Old 11-14-2003, 09:23 PM
CSX 4027's Avatar
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default Sheet
I would like to see the data sheet. From what I can see there is a real problem. According to my understanding, Horsepower and Torque are suppossed to be equal at 5250 RPM's no matter what. I would ask your builder why yours is at less....
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 11-14-2003, 09:55 PM
Steve, nice observation. I did some research and found out that since the torque and hp are being graphed on different scales their point of intersection is arbitrary.
You had me worried though *whew*.
Old 11-14-2003, 09:57 PM
CSX 4027's Avatar
Default ???
No Comprendo!!!
Splain Lucy?
Do you have the data sheet or just the graph?
Steve Sunshine
"Hurry Up And Live"
Old 11-14-2003, 10:20 PM
Steve,
I do, but it's on another computer.
Here's the pertinent data:
5200 RPM HP = 438.8 TORQUE = 443.7 (Torque is Higher)
5300 RPM HP = 445.9 TORQUE = 442.2 (HP is Higher)
Thus the two intersect somewhere in between - you guessed it, at 5250 RPM.
The reason the above dyno does not show the intersection at 5250 is a result of different scales being used for torque and HP - the two vertical axis do not represent the same number scales. Due to that difference the HP and torque curves can't be compared on a visual basis. As to why one wouldn't always use the same scale, I couldn't say.
Old 11-15-2003, 01:25 PM
Cobra Make, Engine: B+B 351w #112
What heads? What cam? We want engine specs!
Old 11-15-2003, 02:00 PM
http://www.perfeng.cc/engines.html
That is the link to all of Eric's engines. This is a 351 with .544 cams - but notice it get's as much HP as the 418 stroker! (Although not nearly as much torque). It's possible the high HP numbers are a result of something Eric did to the engine to allow it to rev a bit higher than normal. I'll have to ask.
-Adam
