1Likes
07-16-2005, 09:33 AM
Thanks Warren.
02-11-2008, 07:08 PM
ct
Does anyone know the trick to get the old bootoff and the new boot on with out damaging it?
I want to avoid tearing it. It is a finish line boot, and I have a top loader with the lockout on the shifter.
Thanks...Dave
02-11-2008, 10:28 PM
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Take the ball off and then loosen the set screw inside. The "T" reverse handle slides off then you can remove the boot. Reverse the order after you install the new boot.
I had the same "binding" problem when I switched to the Hurst stick. I used the leather boot from Cobra Valley and saved the rubber boot and Mustang reverse shifter and mount for later use if I want to switch back. Shifts a lot faster and smoother with the Hurst....although you don't have the originality look. I prefer the smoother shift.
02-11-2008, 10:41 PM
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
I had a local leather shop make a 'custom' boot for me...looks fabulous...works perfectly!
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
07-14-2021, 02:21 PM
NJ
Shift Boot-ing me outta second gear!
I know it's an old thread, but it helped solve my issue. Just ordered the Sunbeam Tiger boot from Sunbeam Specialties and they still carry that part.
07-14-2021, 02:56 PM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
I installed the shifter boot from Cobra Valley and couldn’t be happier. Shifts much smoother, looks great and doesn’t kick out of gear in 2nd and 4th like it did with the rubber boot.
07-14-2021, 05:47 PM
IA
Cobra Make, Engine: Shell Valley-408
Funny that this post was revisited as this just happened to me last week on my Hurst shifter 5 speed on my brand new Cobra. Thought at first that it was the trans problem. but we figured out that it was the boot. I plan on replacing the still rubber style boot with a leather one. That should do it. Interesting that other have had the same problem.
07-14-2021, 06:05 PM
Senile Club Cobra Member
We have a very nice shift boot as per the original Ford unit used in Cobras and Tigers. It is softer than the factory boot so no pulling out of gear issues. https://www.timemachineauto.com/parts-accessories/
rick@autoventureusa.net
07-15-2021, 04:44 AM
ON
Originally Posted by Mark IV
I bought one of these from Rick and installed it the other day. It fits perfectly and is nice and supple. No issues whatsoever with the boot binding and popping the shifter out of gear.
07-15-2021, 06:24 AM
The boots that we use can be stretched (carefully) over the T handle on the shifter.
07-15-2021, 08:07 AM
IA
I usually heat the boot up in boiling water and it then stretched over the T lockout lever.
07-15-2021, 11:23 AM
Cars that have a Tremec transmission have a dummy "T". If you remove the shifter ball you can access the Allen set screw that retains the "T". No worries with stretching the bot if the "T" is not there.
09-25-2023, 08:10 AM
MN
Cobra Make, Engine: Superformance MkIII Roadster
Or...you can simply lift the old boot, unbolt the shifter from the Tremec, then slide the boot on from the bottom of the shifter handle...
09-26-2023, 02:23 AM
I love reading these old threads....
