| 29 |
08-10-2007, 10:05 AM
Member of the north
Cobra Make, Engine: A Cobra
If I glass bead...
I recently have had a few challenges with my car.
I have a cracked throttle body on my carb and my side pipes are cracked.
SO, I am replacing the carb, but the side pipes I am going to have welded. Once welded, I was thinking of glass beading them.
They are ceramic coated and Lone Star will not warranty them as they are over a year old.
Here's the question: If I glass bead the pipes, will it destroy the ceramic coating over the pipes?
Second question: if your pipes were cracked and they were ceramic coated, would you weld and re-coat? What advice would you give?
08-10-2007, 10:25 AM
You have to remove the ceramic coating in the area you are going to weld.
If that will show then re-coat them. If not just hit with some VHT paint that matches the ceramic coating.
08-10-2007, 12:28 PM
FL.
Cobra Make, Engine: n/a
How are your sidepipes mounted? Are they able to move with the motor? If not, then maybe you need to mount them differently, so they will move. I posted picks of a possible solution earlier.
http://clubcobra.com/forums/showthread.php?t=81252
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
08-10-2007, 01:18 PM
AL
side pipes
My Lone Star side pipes cracked at the body mount location the first year. I had a local muffler shop to repair them. He ground the ceramic off the area where he was going to weld. He mig welded a curve plate (a piece made from a pipe) over the cracked spot. Then he welded the mounting bracket to the plate. 18,000 miles later and it's still good. He painted the spot with high temp silver, but later I had the pipes recoated. They can do a spot repair on the ceramic.
If you glass bead the pipes "very" lightly it will not remove the ceramic. Be carefull. Ceramic is a thin coating.
Dwight
This is the best pic I have of the mounting tab near the rear of the side pipe. This is where mine cracked.
08-10-2007, 02:59 PM
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Dwight,
Love your ramps, where did you get them?
Jerry
08-10-2007, 04:15 PM
Member of the north
Dwight
That is the place they broke. Also happens to be on that side. The other break I can fix.
I will drop the pressure onthe bead blaster and clean it up before I cover it.
Thanks!!
08-10-2007, 04:19 PM
Member of the north
I was at London. I worked as EVENT STAFF.
Dwight, when did you arrive?
08-10-2007, 08:25 PM
AL
ramps
I made my ramps out of scrap wood and metal. You can make them out of wood and just paint them. I got the ideal from someone on the Form.
We arrive at the Hampton on Thursday morning. You Guys did a great job. Thanks and see ya'll next year.
Dwight
08-12-2007, 04:21 PM
Thanks for the pic of your ramps, might be a future winter project.
Jerry
