| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
10-02-2007, 12:13 AM
ca
Cobra Make, Engine: classic roadster,408cu
OK has anyone even seen one of the quick jacks?
Iam interested in building one ...need info .
10-02-2007, 12:44 AM
PA
Awesome picture of the quick jack in use. I don't think I've ever seen another.
 Bagram AF Afghanistan
10-02-2007, 12:49 AM
CA
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Shelby strongly recommended against using the quick jacks. Basically the jacks are attached with all thread. I am sure any of the quick jacks used on todays cobra's would have to be strongly reinforced.
Morgan LeBlanc
Fresno CA
10-02-2007, 01:02 AM
Ca
As mentioned by Morgan very few of the cars have the subsructure or actual framework to be able to support the weight of the car from the Quickjacks. They are for the most part "Ornamental", sort of like Earings on a pig.
Rick
10-02-2007, 03:11 AM
FL
You see them all the time at drag races in the pits and most are home made but this one is only $1,800
http://www.davidlemmond.com/superjax.html
Dan Wulff
10-02-2007, 06:07 AM
ny
Cobra Make, Engine: Gary Edwards Racing 460
On SPF's they are not functional. Not sure about the other makes.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
10-02-2007, 06:23 AM
Canadian Gashole
QC
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I would think that they would probably move enough to crack the fiber glass.  I tried to reinforce mine when I built the car but I have never put them to the test.
Wayne
Don't get caught dead, sitting on your seat belt.
10-02-2007, 07:03 AM
Cobra Make, Engine: Backdraft cobra, Ford motorsports 302, holly carb
I tried using mine on a Backdraft and was afraid the body would crack - they flexed like crazy as soon as the jack started up.
10-02-2007, 07:59 AM
Ca
With a keen eye, it can be seen on the FIA cars the area around the lateral quickjack supports that protrude through the body is relieved (cut away) to allow for potential movement under load while lifting. Evidently Shelby & crew were aware that there was flexing of the tubular substructure.
Rick
10-02-2007, 08:10 AM
tx
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
They do not work on ANY Cobra, they really didn't work on the 60's cars either. The jacks and the bodies would bend under the stress.
" It ain't no big deal"
10-02-2007, 08:26 AM
Member of the north
Cobra Make, Engine: A Cobra
I would agree that the body would crack or the extentions would bend at the weight of the car on the jacks.
Have you tried these?
10-02-2007, 08:40 AM
FL
I have never even thought about using a quick jack and my C3 Corvette frame has the complete bumpers attached plus my car weighs in at 1,000lbs more than most Cobras. As I said you can see these quick jacks used in the pits of most drag cars but they are used on very light weight cars. If you where building your Cobra yourself and wanted to use a quick jack and made sure the jacks were secured to the frame by welding or using adequate sized bolts, I’m sure it would be an easy install for your build.
Dan Wulff
10-02-2007, 08:49 AM
Banned
CA
The other detail that most don't notice is that the quick jack orientation on the car is actually BACKWARDS (i.e. the BIG tang is toward the back or the body side of the car). I first noticed this in a Cobra book my wife bought for me last Christmas. Makes since given the fact that you wanted an easy 'guide' of sorts to engage the lever.
Or said another way, all of the current reproduction Cobras have the quickjacks facing the wrong direction.
-Dean
10-02-2007, 08:50 AM
TX
fsstnotch,
That is such a great photo! The dirt surface, hammer laying around, check out the guy on gas and the hose! And the driver out of the car behind the "wall." The guy with a bandana in his back pocket. How cool. The guy working on the tire looks like he's injecting something into a hole in the tire or something. So different than today's pit stops.
MadMiles442
10-02-2007, 10:16 AM
Abnormal CC Member
PA
-Dean
I think the quickjacks had to be "backwards" on the cars with oil cooler scoops. So just because they are "backwards" does not make them "wrong".
10-02-2007, 10:24 AM
CA
Cobra Make, Engine: Shelby CSX4795 (Sold)
Mine work!
I've used mine several times without issue.
I have a long steel 'digging' bar. It's about 3/4" diamater. I put it on my floor jack and center it between the quick jacks. Lifts the car with 2 pumps.
jdog
"If you can't run with the BIG DOGS, stay under the porch!"
10-02-2007, 10:25 AM
I'd always heard that the quickjacks were nonfuctional, but I've seen the late Mac Archer's Cobra elevated that way on more than one occasion at Monterey. Didn't seem to do any harm.
10-02-2007, 10:43 AM
Abnormal CC Member
PA
jdog
When you get the Kirkhams to rebody your cobra, you might not want to do that anymore. I'm pretty sure the Kirkhams have strongly discouraged using quick jacks on clubcobra or their website.
10-02-2007, 11:53 AM
Banned
CA
My point was strictly 'functional'. I just find it ironic that all of the old Cobra pics show the quickjacks oriented exactly the opposite that you see ALL of the manufacturers today build them (even Shelby!). Someone must have decided at one point that the 'big end out' either looked better or, maybe, it was proven after the fact to be more functional!
10-02-2007, 12:06 PM
Abnormal CC Member
PA
Or facing them backwards from the early 289 car orientation proved functional in that you did not crush your oil cooler scoop when you jacked up the car?
