Old 10-09-2007, 01:27 PM
Cobra Make, Engine: contemporary, 427 chevy
Default exhaust noise
Every two years it's a pain in the ass going through Delaware inspection and I’m barely over the decibel limit. Is there a product on the market or something that can be made, without a machine shop, to temporarily slip into the side pipes to make these people happy for ten minutes? Any suggestions will be greatly appreciated.
Old 10-09-2007, 01:30 PM
imagine2frolic's Avatar
Cobra Make, Engine: n/a
Send a message via Yahoo to imagine2frolic
It is possible to slip a reducer inside of the tip. One simple hole, and it will screw into place. Just like on the imports.
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
Old 10-09-2007, 02:12 PM
Silverback51's Avatar
Looks to me like you need the Exhaust Tampon.
Old 10-09-2007, 02:51 PM
bobcowan's Avatar
You could try something like. Cram it in to the end of the pipe for the inspection, then pull it out.
Old 10-10-2007, 05:47 AM
I had another thought. A customer came in in an import with one of those cans on it. Claiming it was way to loud. It had the softest little purr to it. I asked him what he meant by loud, and then he showed me the 0000 steelwool stuffed up inside of the can. I hooked a piece of welding rod, and just pulled it all out. SIMPLE!
Old 10-10-2007, 07:36 AM
Wayne Maybury's Avatar
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Yes, a bunch of steel wool stuffed in and held in place somehow will cut the noise level quite a bit.
Years ago, I got a 24 hour warning for noise with my Hi Po Mustang. I just stuck a couple of those VW exhaust extensions up the tail pipes and put a spot of brass weld on each one. The noise reduction was amazing but of course the car ran like crap until I passed the inspection and removed the exyensions.
Wayne
Don't get caught dead, sitting on your seat belt.
Old 10-10-2007, 06:20 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
kalecoauto.com
Old 10-10-2007, 07:42 PM
Cobra Make, Engine: ??? THIRD OWNER OF UNFINISHED CAR,THINK ORIGINAL BUILDER WENT BELLY UP
As A Kid ,my Duel Glass Packs Got A Lot Of Neg. Att. Steal Wool Wrapped Around A Coat Hanger Got Me Thru Insp. And The State P.d.
Old 10-11-2007, 10:39 AM
khansmith's Avatar
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
I have seen mixed reviews on these but I am planning on trying them...inserting them into the end of the pipe:
http://www.jegs.com/webapp/wcs/store...10002_59838_-1
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
Old 10-11-2007, 06:00 PM
bobcowan's Avatar
I used a Vortex Cone in a turbocharged Harley. It had a megaphone pipe with no baffles. The turbo softened the note a little, but it was still loud. Can't say the cone did any good at all. It changed the tone a little at idle, but not during riding. 1 month after I installed it, I got a loud pipes ticket.
Old 10-12-2007, 05:48 AM
khansmith's Avatar
That's good to know! Thanks for sharing.
From what I have read in NJ rules/regs, there is no DB hard fast rule. It seems that the rule is you can't have open pipes. This just gets me that check mark. Could always stuff some muffler in front before the install.
Old 10-12-2007, 07:54 AM
Don Don is offline
The advertised reduction with the vortex cone is 1 to 3 dB and clarified by use of the word " typically "
Do not recall the source, but vaguely remember the Vortex approach is more effective prior to the muffle as pictured:
http://www.afabcorp.com/AFCO_Dynatec...rtex_conesonly
Old 10-12-2007, 09:16 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Lightbulb
Anyone ever use SuperTrapps?
http://www.supertrapp.com/product_se...auto/index.asp
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 10-12-2007, 10:29 AM
Supertrapps were a very popular installation many years ago. 20 years ago we use to install them all the time, but they faded away. I think people got tired of adjusting the plates. They seemed like a good idea to me?
