11-20-2007, 10:23 AM
Mo
Cobra Make, Engine: SVM7688, 427 FE med riser, doug nash 5-speed, 3.54 9 inch locker.
Turkey Pan ?
Wondering what a fair price range is for used pans these days, have got one I'm thinking of moving, thanks in advance. Don
Objects in the mirror are losing
11-20-2007, 04:50 PM
Mo
Nobody
11-20-2007, 05:03 PM
Originally Posted by viking
Nobody
$50, maybe.
11-20-2007, 05:12 PM
Mo
Thanks, I'll put some pics up if anyones interested.
11-20-2007, 06:02 PM
ill take that turkey.....pan.
post some pics, then we can hash out the details.
jason
11-20-2007, 06:29 PM
Mo
11-20-2007, 06:33 PM
My wife says she'll have one you can buy cheap late Thursday. I think the gravy will clean out OK.
Ned Scudder
11-20-2007, 09:41 PM
I think $50 is a smoking deal! I would buy it in a second if I didn't have dual quads.
11-20-2007, 09:49 PM
Mo
O.K. after checking all over for prices, $75.00 takes it, shipping included, to U.S. only.
11-21-2007, 06:05 AM
then pan
viking,
pm me your info and we can set up a payment arrangement.
thanks
jason
11-21-2007, 06:07 AM
Don't forget the appraiser's commission.
11-21-2007, 06:24 AM
OK
I paid $100 for mine used about two years ago. Took it off because I needed a bigger air cleaner when racing. May put it back on for town cruises, it looks cool.
Clois
"Let's roll"
"Be part of Something Good
11-21-2007, 10:56 AM
Mo
viking,
thanks
jason
PM sent
and thanks patrickt
11-21-2007, 11:49 AM
Originally Posted by Clois Harlan
I...Took it off because I needed a bigger air cleaner when racing. May put it back on for town cruises, it looks cool.
Clois
Indeed it does look cool. Now, if you did this, switching it out would be a piece of cake. Not to mention making the carb adjustment easier. I don't get the credit for this fabrication, Bob P. did it for me last year.
11-21-2007, 11:58 AM
Mo
Cool idea
11-21-2007, 06:12 PM
Cobra Make, Engine: HI-TECH 289 FIA
Are those springs on the side necessary?
What do they do?
fiaroadster
11-21-2007, 07:14 PM
What do they do?
The Terry Body Springs hold the Turkey Pan down to the base. You could probably run without them, but the pan might then rattle on top of the base. The TB springs eliminate that possibility. Here's a better shot of them, you can see that I have them safety wired together just in case one of them vibrates loose, which has yet to happen.
11-21-2007, 07:46 PM
So those vertical studs are locating pins? I thought they were captured bolts to secure the top half with nuts. I see the purpose now.
fiaroadster
11-22-2007, 10:05 AM
Il
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
Good idea with the safty wire. How long does it take to remove the pan with this set-up? I usually keep my pan off for everyday driving (I believe it breathes better that way) but I like to put it on for shows. -It's just such a pain in the a$$!
11-22-2007, 10:22 AM
It takes less than a minute. You just pull the springs off with your fingers and then lift the pan right off (it requires a little maneuvering, but not much). No need to remove the air cleaner, or anything else for that matter. I tune my carb with a vacuum gauge. I honestly don't know how I would get the hose on the base of my Holley with my fat stubby fingers if the Turkey Pan was on there. Being able to pull it off makes a huge difference when working on the carb.
