January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 11-20-2007, 11:23 AM
viking's Avatar
Cobra Make, Engine: SVM7688, 427 FE med riser, doug nash 5-speed, 3.54 9 inch locker.
Default Turkey Pan ?
Wondering what a fair price range is for used pans these days, have got one I'm thinking of moving, thanks in advance. Don
Objects in the mirror are losing
Old 11-20-2007, 05:50 PM
viking's Avatar
Nobody
Old 11-20-2007, 06:03 PM
Originally Posted by viking
Nobody
$50, maybe.
Old 11-20-2007, 06:12 PM
viking's Avatar
Thanks, I'll put some pics up if anyones interested.
Old 11-20-2007, 07:02 PM
ill take that turkey.....pan.
post some pics, then we can hash out the details.
jason
Old 11-20-2007, 07:29 PM
viking's Avatar
Here it is
Had a holley 800 double pumper in it.
Old 11-20-2007, 07:33 PM
Nedsel's Avatar
Original Shelby Owner
My wife says she'll have one you can buy cheap late Thursday. I think the gravy will clean out OK.
Ned Scudder
Old 11-20-2007, 10:41 PM
LMH's Avatar
LMH LMH is offline
I think $50 is a smoking deal! I would buy it in a second if I didn't have dual quads.
Old 11-20-2007, 10:49 PM
viking's Avatar
O.K. after checking all over for prices, $75.00 takes it, shipping included, to U.S. only.
Old 11-21-2007, 07:05 AM
Default then pan
viking,
pm me your info and we can set up a payment arrangement.
thanks
jason
Old 11-21-2007, 07:07 AM
Don't forget the appraiser's commission.
Old 11-21-2007, 07:24 AM
Clois Harlan's Avatar
I paid $100 for mine used about two years ago. Took it off because I needed a bigger air cleaner when racing. May put it back on for town cruises, it looks cool.
Clois
"Let's roll"
"Be part of Something Good
Old 11-21-2007, 11:56 AM
viking's Avatar
viking,
thanks
jason
PM sent
and thanks patrickt
Old 11-21-2007, 12:49 PM
Originally Posted by Clois Harlan
I...Took it off because I needed a bigger air cleaner when racing. May put it back on for town cruises, it looks cool.
Clois
Indeed it does look cool. Now, if you did this, switching it out would be a piece of cake. Not to mention making the carb adjustment easier. I don't get the credit for this fabrication, Bob P. did it for me last year.
Old 11-21-2007, 12:58 PM
viking's Avatar
Cool idea
Old 11-21-2007, 07:12 PM
Cobra Make, Engine: HI-TECH 289 FIA
Are those springs on the side necessary?
What do they do?
fiaroadster
Old 11-21-2007, 08:14 PM
What do they do?
The Terry Body Springs hold the Turkey Pan down to the base. You could probably run without them, but the pan might then rattle on top of the base. The TB springs eliminate that possibility. Here's a better shot of them, you can see that I have them safety wired together just in case one of them vibrates loose, which has yet to happen.
Old 11-21-2007, 08:46 PM
So those vertical studs are locating pins? I thought they were captured bolts to secure the top half with nuts. I see the purpose now.
fiaroadster
Old 11-22-2007, 11:05 AM
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
Good idea with the safty wire. How long does it take to remove the pan with this set-up? I usually keep my pan off for everyday driving (I believe it breathes better that way) but I like to put it on for shows. -It's just such a pain in the a$$!
Old 11-22-2007, 11:22 AM
It takes less than a minute. You just pull the springs off with your fingers and then lift the pan right off (it requires a little maneuvering, but not much). No need to remove the air cleaner, or anything else for that matter. I tune my carb with a vacuum gauge. I honestly don't know how I would get the hose on the base of my Holley with my fat stubby fingers if the Turkey Pan was on there. Being able to pull it off makes a huge difference when working on the carb.
