Old 12-03-2007, 07:33 AM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default looking for Sidepipe Gasket
Hello All,
I would like to know where the best place to buy the sidepipe gaskets.
The gaskets I am looking for has 8 bolt holes. I have been looking everywhere and I can not seem to find them.
Old 12-03-2007, 08:16 AM
Club Cobra Member
Cobra Make, Engine: Former Everett-Morrison,428SCJ
Hi Pri,
You can get the gasket material from Summit, and cut them yourself. The stuff is not easy to cut. I drilled through it with a wood bit, and then finshed it up with a sanding drum on a Dremel. Clamp the gasket to the sidepipe flange and the pipes will act as a guide.......you may not want to do this if your pipes are coated(mine are stainless).
-Jon
Old 12-03-2007, 08:24 AM
priobe's Avatar
Yes,
My pipes are coated
Old 12-03-2007, 09:38 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
You can use the "plastic hammer" when getting the outline.
PLace the gasket over the flange and tap lighting with the plastic hammer. The outline of the area to be "gasketed" will appear on the material.
Mr Gasket makes blank sheet Exhaust gasket material.
Old 12-03-2007, 10:35 AM
priobe's Avatar
Thanks for the suggestion, if I can not find them premade I guess I will have to make my own.
Isnt there a company that makes these premade?
Old 12-03-2007, 10:47 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Napa sells sheets of gasket material too.Mine was $12. for a very large sheet ,seemed like it was to cheap.worked well for header to side pipe too.Summit has pre-made gaskets for everything at a price.
the older i get the faster i was.
Old 12-03-2007, 10:59 AM
Silverback51's Avatar
I got mine from Park Place which is a Superformance dealer.
You might check to see if there is a dealer near you.
Old 12-03-2007, 01:35 PM
Gene Gorman's Avatar
Cobra Make, Engine: SPF#2279 Alum.Shelby 484ci
Call Dave Cope at Superformance 949-900-1960 He should have them in stock. part#SUP-00-006-00033 you will need to order 2
Old 12-03-2007, 04:23 PM
Cobra Make, Engine: SPF 974
All you really need is Permatex Ultra Copper High Temp Silicone.
Run a bead all around the flange and bolt holes and you should be fine. Mine have been through 4 seasons with the Ultra Copper sealing sidepipe to header. Many guys also use the permatex as a header gasket.
http://www.acehardware.com/product/i...ductId=1295860
Old 12-03-2007, 07:53 PM
Dwight's Avatar
Smile sidepipe gaskets
I blew out Mr Gasket gaskets, Hi-Temp sealants, everything I tried, I blew out. I bought a sheet of laminated aluminum (.048" .003" 9574K32 $56.07). I used a hamner to outline the gasket, hole cutters to cut the large and small holes and tin cutters to cut the outside edge of the gaskets. One year, 5000 miles and no leaks.
http://www.mcmaster.com/
Dwight
I could sell you enough material to do two gaskets if you want. Just give me to size you need. 6" x 6" $8 a pair plus a little shippping.
Thickness
.006" | .008" | .010" | .016" | .020" | .021" | .032" | .033" | .048" | .062" | .094" | .124" | 1/8" | 3/16" | 1/4" | .063"
Laminated Layer Thickness
.002" | .003"
These 19 products match your selections
Thickness Laminated Layer Thickness Each
.006" .002" 9574K11 $17.13
.008" .002" 9574K12 18.34
.010" .002" 9574K13 21.07
.016" .002" 9574K14 23.44
.016" .003" 9574K25 21.73
.020" .002" 9574K15 37.23
.021" .003" 9574K27 34.84
.032" .002" 9574K16 43.51
.033" .003" 9574K31 38.69
.048" .002" 9574K17 48.37
.048" .003" 9574K32 56.07
.062" .002" 9574K18 66.82
.094" .002" 9574K19 96.51
.094" .003" 9574K34 99.37
.124" .002" 9574K21 107.42
1/8" .003" 9574K35 132.64
3/16" .003" 9574K61 178.60
1/4" .003" 9574K62 259.06
.063" .003" 9574K33 74.15
Old 12-03-2007, 07:59 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Jam is right, use permatex, gaskets won't work.....
" It ain't no big deal"
Old 12-04-2007, 05:11 AM
TButtrick's Avatar
Yup. No gaskets here for 50,000 miles. Just the Permatex Ultra Copper.
