| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
03-10-2008, 11:08 PM
AR
New Kirkhams, all aluminum FE engine for under 99,000.00
We can offer new Kirkhams for under 99,000.00 with new all aluminum 482C.I. FE engine and Tremec TKO 600 transmissions. Through our great relation ship with the Kirkham's we are able to help you with your Kirkham needs. We have built several of these cars and learned a lot of neat things to do to them and have several different engine packages available. In an effort to make sure that our customers get the quality they deserve and to check out the engine after the installation we have started doing complete turn key installs. We like to test drive the cars for about 100 miles to check all of the systems on the car and engine for proper working order. Call us with your needs. We have one complete car ready right now and several more coming for sale as rollers or we can build them complete for you. Thanks, Keith Craft
Keith C
03-11-2008, 05:44 AM
Fl
Cobra Make, Engine: BDR # 165 392 Ford Crate 430HP
What is the total weight of car with the aluminum 482 engine & also whats the weight of the complete 482 engine carb to oil pan..
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
03-11-2008, 05:46 AM
Fl
I forgot one more question.. do you take trades as I have some realestate that no one seems to want  and it's not even swamp land
03-11-2008, 07:21 AM
Member of the north
Cobra Make, Engine: A Cobra
trs900, your in Florida. Isn't land there kind of "in forclosure"?
03-11-2008, 07:26 AM
TRS900,
Hopefully I am not stepping on Keith's toes by answering this question... We have weighed our cars with aluminum big blocks at 2180 pounds.
03-11-2008, 07:46 AM
Fl
Joe thanks for the info..
Trularin.. land is not in forclosure its just now being considered as down under.. what were not sure ??
With all the traffic you would think we are in a boom time, winters up north harsh as ever come on down and I will hook you up.  even throw in a mini yacht.. see pic [IMG]  [/IMG]
03-11-2008, 09:00 AM
Joe, thanks for the weight info. I was wondering about that little factoid.
03-11-2008, 10:18 AM
AZ
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
$45.41 a lb. Not a bad price for all that arruminum.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
03-11-2008, 10:26 AM
Hey Joe, about the Kirkham's weight, did that car have a Quicktime bellhousing and one of your aluminum rear end housings? Were there any other special or out of the ordinary weight reduction items? Thank you.
03-11-2008, 02:04 PM
Cobra Make, Engine: KMP
moved to KMS weight post.
Note to moderator: please delete this post.
Lew
I'm no expert.
Reason: moved to appropriatye post.
03-11-2008, 09:04 PM
AR
Kirkham weight
Like Joe said the cars will weigh in the 2140 to 2190 depending on the engine and a few options. That is with the Kirkham aluminum rear end which is the only way that we get them. I had a Kirkham that we took to Run-N-Gun a couple of years ago with a Shelby block all aluminum 527 FE that weighed 2150 with 10 gallons of fuel. We put it on the scales after setting the ride height and could not believe that the car was within 8 pounds on all four corners. That was prety neat and the car worked real well. Thanks, Keith
Keith C
03-15-2008, 03:01 PM
keith what kirkham options are included in this price?
thanks
03-16-2008, 04:08 PM
AR
This is either the brushed or polished aluminum car with the opposite stripes, visors, side vents, wheel foam, complete oil coller system, Kikrham billet aluminum hydraulic clutch linkage system, side pipes, billet engine and trans mounts, wool carpet, trunk mounted battery, billet over flow tank, larger front brkaes, Penske shocks, billet lift jacks, all aluminum 482 FE engine with TKO 600 transmission, bell housing, McCloed flywheel, clutch and pressure plate, billet shifter, drive shaft with installation, set up, alignment, tuning and test driving for at least 50 miles to check all items. The engine is dyno tested before installation and tuned after installed. There are a few options I probably forgot to list. Feel free to call with any questions. Prices will be going up on next shipment of cars. Thanks, Keith
Keith C
